Import from Word creates bad html
Dec 17, 2013 1:53 PM
using Word 2010 and Robohelp 10
I cannot find a "convert text to table" option in Robohelp so I assume you must create the table from scratch or import the table, correct?
Importing word docs using tables and lists creates html with a lot of formatting garbage (in my opinion)
  1. i created Word doc with only a simple table that only used the most basic "table grid" word table style format.
  2. Imported the word doc into my robohelp project
  3. set the table import style to "simple border"
The html is cluttered with really poor tagging garbage.
Is there a way to create tables in Word that will create unformatted tables in Robo Help?
sample:
<body>
<table class="SimpleBorder" cellspacing="0">
<tr>
  <td style="vertical-align: top;" width="213"><p style="margin-bottom: .0001pt;
               line-height: normal;">This
   is the first column heading</p></td>
   is second column heading</p></td>
   is third column heading</p></td>
</tr>
<tr>
               line-height: normal;">Column
   one, second row</p></td>
   two, second row</p></td>
   three, second row</p></td>
</tr>
<tr>
   one, third row</p></td>
   two, third row</p></td>
   three, third row</p></td>
</tr>
</table>
<p>&#160;</p>
<p class="ListParagraphCxSpFirst" style="text-indent: -.25in;">1.<span
  style="font: 7.0pt 'Times New Roman';">&#160;&#160;&#160;&#160;&#160;&#160;</span>&#160;Ordered
list step 1</p>
<p class="ListParagraphCxSpMiddle" style="text-indent: -.25in;">2.<span
list step 2</p>
<p class="ListParagraphCxSpLast" style="text-indent: -.25in;">3.<span style="font: 7.0pt 'Times New Roman';">&#160;&#160;&#160;&#160;&#160;&#160;</span>&#160;Ordered
list step 3</p>
<p style="margin-left: .25in;">&#160;</p>
</body>
    Dec 17, 2013 2:42 PM   in reply to jeffc2010
    Easier than you expect.
    Paste in, complete with garbage.
    Right click and select a CSS table.
    Important. Select Clean inline styling.
    Usually does the job.
    Dec 18, 2013 1:49 AM   in reply to jeffc2010
    You used the right option, I gave you the wrong procedure, apologies.
    Paste your table in and then select it in Rh. On the Format menu there is a Clear Formatting option. Click that and you will have a clean table to which you can then apply a CSS table if required.
    @petergrainge
    Dec 19, 2013 1:10 AM   in reply to jeffc2010
    That's a known issue and it should be OK in most browsers. To fix it in Rh's Design Editor apply a table width and column widths.
    @petergrainge
    Dec 23, 2013 8:28 AM   in reply to Peter Grainge
    Because we experience so many issues with tables being created by others, we are simply capturing the tables as graphics and putting them in as pictures.  It's the only way to get the tables the way the authors want and keeps us from beginning to look like Peter prematurely that is.  (hehe!)
    Dec 23, 2013 11:46 AM   in reply to imagineimage1
    Well I may have a few wrinkles but my tables look better than yours!
    Have you tried the Clear Formatting option as it leaves only really basic table code?Then apply a CSS style and the table is perfect.
    @petergrainge
    Dec 23, 2013 1:05 PM   in reply to jeffc2010
    @jeffc2010 My last post was in response to ImagineImage1.
    @petergrainge
    Dec 23, 2013 2:31 PM   in reply to jeffc2010
    Sometimes I have had to click that clear button a few times before it actually cleans totally or so it seems.
