cheshta
Error: Server accepted your connection, but refused your privilege to record?
Dec 18, 2013 2:30 AM
Tags: #problem #adobe #video #rtmfp #server #fms #media #rtmp #stream #record #fms_4.5
Hi guys,
I'm developing an EJB application with Glassfish and Adobe Flash Media Server and MySQL at the backend. I have a page in my application with which I record a feedback of the user. I'm using the Adobe Media Flash server for this. I've set my host path to rtmp://localhost:1935/ as the flash server is installed on my local machine. I've loaded my application on Adobe Media Administration Console. Whenever I run this feedback page I get a "Server accepted your connection, but refused your privilege to record" error.
My js file as below:
Widget.VideoPlayer = Class.create(Widget, {
          classType: 'VideoPlayer',
          objectId: "videoPlayerObject",
          player: null,
          width: 500,
          height: 375,
           * Note that the instance of this object must be global and be named the same as the id so that the flash player can call it back.
          initialize: function(id, objectId, width, height) {
                    this.id = id || this.id;
                    this.objectId = objectId ||this.objectId;
                    this.width = width || this.width;
                    this.height = height || this.height;
                    if(typeof swfobject == "undefined")
                              return this.showError("The VideoPlayer widget requires that the swfobject library be imported");
                    this.createPlayer();
          createPlayer: function() {
                    var flashvars = {
                    var params = {
                              menu: "false",
                              scale: "noScale",
                              allowFullscreen: "false",
                              allowScriptAccess: "sameDomain",
                              bgcolor: "#99AAC9",
                              wmode: "opaque"
                    var attributes = {
                    swfobject.embedSWF(
                              "/includes/swf/myapp/ProjmyappPlayer.swf",
                              this.objectId, this.width, this.height, "10.0.0",
                              "/includes/swf/myapp/expressInstall.swf",
                              flashvars, params, attributes);
                    // There is a delay before the object appears on the page and no callback event
                    var checkLoaded = setInterval(function(){
                              if($(this.objectId).tagName == "OBJECT") {
                                        try {
                                                  this.player = $(this.objectId);
                                                  this.setId(this.id);
                                                  this.player.player = this; // circular reference
                                                  clearInterval(checkLoaded);
                                                  this.dispatch("onPlayerCreate");
                                        } catch(ex) {
                                                  this.log("Failed Loading: "+ex);
                    }.bind(this), 500);
           * Player Invocations
          setId: function(id) {
                              this.player.setId(this.id);
          setServer: function(serverName) {
                    this.player.setServer(serverName);
          setVideo: function(videoName) {
                    this.player.setVideo(videoName);
          setVideoServer: function(serverName, videoPath, videoName) {
                    this.player.setVideoServer(serverName, videoPath, videoName);
          setQueryParam: function(paramName, paramValue){
                    this.player.setQueryParam(paramName, paramValue);
          play: function() {
                    this.player.playVideo();
          pause: function() {
                    this.player.pauseVideo();
          record: function() {
                    this.player.recordVideo();
          stop: function() {
                    this.player.stopVideo();
          showError: function(message, title) {
                    title = title || "Video Player Error";
                    (new Widget.Dialog(title, message)).showDialog();
                    return null;
          enableWebcam: function(){
                    this.player.enableWebcam();
          setAllowReRecord: function(allowRerecord){
                    this.player.setAllowReRecord(allowRerecord);
          setRecordLimit: function(recordLimit){
                    this.player.setRecordLimit(recordLimit);
          showSettings: function() {
                    this.player.showSettings();
          showWebcamSettings: function() {
                    this.player.showWebcamSettings();
           * Player callback events
          onPlayStart: function() {
                    this.dispatch("onPlayStart");
          onPlayStop: function() {
                    this.dispatch("onPlayStop");
          onConnectingStart: function() {
                    this.dispatch("onConnectingStart");
          onRecordStart: function() {
                    this.dispatch("onRecordStart");
          onRecordStop: function () {
                    this.dispatch("onRecordStop");
          onConnectionFail: function() {
                    this.dispatch("onConnectionFail");
          onCameraReady: function(){
                    this.dispatch("onCameraReady");
          onPlayerReady: function() {
                    this.dispatch("onPlayerReady");
          onVideoExists: function() {
                    this.dispatch("onVideoExists");
          onSettingsClosed: function () {
                    this.dispatch("onSettingsClosed");
          onRecordBlocked: function () {
                    this.dispatch("onRecordBlocked");
          dispatch: function(event) {
                    window.document.fire(this.id+":"+event);
                    this.log("Fireing Event: "+this.id+":"+event);
          log: function(message) {
                    if(typeof console != "undefined")
                              console.log(message);
Please if anyone could help me remove this error. Thanks in advance.
