joel.chang
How to import pages from one project into another
Dec 18, 2013 9:51 AM
Hi Folks,
I compiled our help documentation into a project and am wondering how I can copy parts of my project into a new project. I'm trying to spilt out the project into smaller ones (management wants to compartmentalize the updating into other units and not have 1 master project). I tried to move my .html folders and supported images etc. into a new project but it wouldn't recognize them.
Besides making multiple folder copies of the entire project then customizing each. Is their a way to import pages from another project? The Resources pod seems to be only for Master Pages etc.
Joel
    Dec 18, 2013 10:07 AM   in reply to joel.chang
    Hi Joel
    To insert existing topics (HTML Pages) into a project, try right-clicking the Project Manager pod. Once you do that you should see an option to Import. You may need to change the bottom of the Import dialog so it shows HTML pages.
    Yes, for the moment the Resource Manager pod does not include topics. Hopefully that will change at some future point.
    Cheers... Rick
    Dec 18, 2013 1:02 PM   in reply to joel.chang
    Hello again
    I'm not sure what you are asking here. It sounds a bit like you may be expecting an easy way to just copy or move a topic from one folder that is part of one project to a different folder that is part of another project. Is this what you are wanting to do?
    If so, you really cannot do that. I mean, you *CAN* move or copy the files, but you cannot expect RoboHelp to know the new file should be part of the destination project. And if moving, RoboHelp will become quite confused and fuss at you as it will be expecting to find the file in the folder and it will have gone missing.
    Here's the deal. A RoboHelp project is much more than a simply conglomeration of HTML files and images. There is a main project database that keeps track of all the files and folders that are part of the project. There are lots of small XML files that track the contents of folders. And other XML files that track links, the TOC, the Index and other items. When you import content, all the associated places and files are updated so RoboHelp knows what to do for each one.
    So as you can hopefully see, it's not as simple as just moving or copying content.
    Cheers... Rick
    Dec 18, 2013 1:03 PM   in reply to joel.chang
    You could create copies and then open each one and trash what is not required there.
    First though, is it that management really want separate projects or separate outputs? If the latter, it might be better to keep one project and use build tags different layouts.
    @petergrainge
    Dec 18, 2013 1:41 PM   in reply to Peter Grainge
    If you want to batch add files and folders to a RH project, you can also
    use my free missing topics fixer script:
    http://www.wvanweelden.eu/product/missing-topics-fixer
    This creates the required files so RoboHelp can pick up missing/new
    files and folders in a project.
    Kind regards,
    Willam
    Dec 19, 2013 11:24 PM   in reply to joel.chang
    I've send you another mail. PM me if you don't receive it or if you run
    into trouble.
    Kind regards,
    Willam
    Dec 23, 2013 12:36 AM   in reply to joel.chang
    I would be asking management for their reasons. It is possible they don't realise what can be done and are storing up trouble.
    @petergrainge
