Comp. 792
Site Wide Background image
Dec 18, 2013 10:10 PM
Tags: #background
I am trying to create a no-repeat background image for my website but after following the steps below I still can't see an image in the background. Here's what I did.
1. First I created a new plain text file named "background.css". In this file I placed the following code.
body {
  background: url("http://www.mywebsite/harper pools/images/backgrounds/blue_sky.jpg") 50% 50% no-repeat;
2. I then Added the following code between the <head></head> tags in the index.html page.
<link rel=StyleSheet href="http://www.mywebsite/harper pools/css/background.css" type="text/css">
3. Then I placed the background image in (harper pools/images/backgrounds/blue-sky.jpg)
4. Finally I uploaded everything, but I can't see any background image.
If someone has any idea what is wrong I would appreciate it. Thanks.
    Dec 19, 2013 2:37 AM   in reply to Comp. 792
    Hi
    If you have uploaded everything can you post a link to the actual page?
    To check that it is not a problem with the positioning of the background image, try changing the 2x50% values to '0'.
    PZ
    Dec 19, 2013 2:39 AM   in reply to Comp. 792
    Try browsing to your site's images folder. Try using your browser's inspect feature to check your code.
    Dec 19, 2013 10:17 PM   in reply to Comp. 792
    Have a look in cache-custom.css
    /* Line 31 */
    #header {
      background-color: #ffffff;
    /* Line 29 */
    #copyright {
    Change the value to transparent.
    Dec 20, 2013 2:51 PM   in reply to Comp. 792
    style.css
    /* Line 189 */
    #header .menu ul {
      list-style-type: none;
      list-style-image: none;
      list-style-position: outside;
    Dec 20, 2013 6:50 PM   in reply to Comp. 792
    Comp. 792 wrote:
    but the white is still behind the menu.
    Try this style in line 231:
    #header .menu.classic > ul {     overflow:visible;     background-color: transparent; }
    Add the item:     background-color: transparent.
    G/L
    Dec 20, 2013 9:46 PM   in reply to Comp. 792
    Look for a p somewhere in your code. Something like #container p {
    Look for anything that says font or size
    Dec 21, 2013 3:43 PM   in reply to Comp. 792
    Perhaps you should start a new thread because it is a new question.  Always start a new discussion when the topic has changed so that you get different views and solutions.
    I went to your links and I don't see anything but my connection is a bit dodgy today.  It has been raining all day here in cold crowded Central London.  People are spending as if there is no tomorrow.
