What is the best export option for a slide show made with Premiere Pro?
Dec 20, 2013 1:36 AM
I have just made a slide show, 3 minutes, some music and 3 slides.
I exported it for youtube with 10fps.
The file ended up with 35 Mb.
Isnt there an export option that allows less fps resulting in a much smaller file size?
    Dec 20, 2013 2:07 AM   in reply to Eireannsg1
    10 fps is the lowest. Why do you want an even smaller size.
    Youtube can handle much larger files and framerates just fine.
    Dec 20, 2013 7:04 PM   in reply to Eireannsg1
    What frame size are you exporting to?
    There is likely a way to get it a little smaller. I will play around with it and see what I can come up with.
    Post a screen shot of your export settings. We might be able to spot a problem.
    Edit: Well, at 1920X1080 a 3 minute slide show starts to fall apart at less than 30MB or so. The bitrate drops to the point where the images are not clear. Anything under about 1Mbps is just too noisy. I used H.264. There might be a better choice for slideshows.
    Dec 20, 2013 9:50 PM   in reply to Eireannsg1
    Try cutting the bitrate in half. If your images still look good, your file should be much smaller. I tried to go below 1.5Mb/s and didn't like it, but 2.5 ought to be OK.
    Dec 21, 2013 2:43 AM   in reply to Eireannsg1
    100 mb does not take hours, I do that in a couple of minutes.
    Unless your connection is super slow.
    Dec 21, 2013 4:21 PM   in reply to Eireannsg1
    Great! Glad to hear you got it worked out!
