I'm a student I have a final project want to deliver it after two days.
I'm making a drag and drop game, I watched a tutorial to do that.
But after ending coding I faced a weird error!
I've I checked that my code is the same as the code in the tutorial.
_________________________________
This is the Debug error report:
Attempting to launch and connect to Player using URL E:\FL\ActionScript\Drag and Drop Project\DragAndDrop.swf
[SWF] E:\FL\ActionScript\Drag and Drop Project\DragAndDrop.swf - 87403 bytes after decompression
TypeError: Error #1034: Type Coercion failed: cannot convert paper1$ to DragDrop.
at Targets()
My `.fla` File is containing 12 Objects to drag and another 12 Objects to drop on it.
The idea here is when drop the Object on the target the Object will become invisible and the target become visible (in `.fla` file `target alpha = 0`).
I made two classes:
DragDrop.as : for the objects that I'm going to drag.
Targets.as : for the targets that I'm going to drop Objects on it.
Note: match function is to animate "GameOver" MovieClip When complete the game.
DragDrop.as:
package
import flash.display.*;
import flash.events.*;
public class DragDrop extends Sprite
var origX:Number;
var origY:Number;
var target:DisplayObject;
public function DragDrop()
// constructor code
origX = x;
origY = y;
addEventListener(MouseEvent.MOUSE_DOWN, drag);
buttonMode = true;
function drag(evt:MouseEvent):void
stage.addEventListener(MouseEvent.MOUSE_UP, drop);
startDrag();
parent.addChild(this);
function drop(evt:MouseEvent):void
stage.removeEventListener(MouseEvent.MOUSE_UP, drop);
stopDrag();
if(hitTestObject(target))
visible = false;
target.alpha = 1;
Object(parent).match();
x = origX;
y = origY;
Targets.as:
package
public class Targets extends MovieClip
var dragdrops:Array;
var numOfMatches:uint = 0;
var speed:Number = 25;
public function Targets()
// constructor code
dragdrops = [paper1,paper2,paper3,paper4,paper5,paper6,
paper7,paper8,paper9,paper10,paper11,paper12,];
var currentObject:DragDrop;
for(var i:uint = 0; i < dragdrops.length; i++)
currentObject = dragdrops;
currentObject.target = getChildByName(currentObject.name + "_target");
public function match():void
numOfMatches++;
if(numOfMatches == dragdrops.length)
win.addEventListener(Event.ENTER_FRAME, winGame);
function winGame(event:Event):void
win.y -= speed;
if(win.y <= 0)
win.y = 0;
win.removeEventListener(Event.ENTER_FRAME, winGame);
win.addEventListener(MouseEvent.CLICK, clickWin);
function clickWin(event:MouseEvent):void
win.removeEventListener(MouseEvent.CLICK, clickWin);
win.addEventListener(Event.ENTER_FRAME, animateDown);
getChildByName(currentObject.name + "_target").alpha = 0;
currentObject.visible = true;
numOfMatches = 0;
addChild(win);
function animateDown(event:Event):void
win.y += speed;
if(win.y >= stage.stageHeight)
win.y = stage.stageHeight;
win.removeEventListener(Event.ENTER_FRAME, animateDown);
...Thanks
that error is telling you dragdrops (for at least one i) isn't a DragDrop object.
from what you posted it's not clear what your dragdrops elements are nor how Targets is obtaining those references.
Thank you very much for replying.
- dragdrops represents: the dragable objects.
- Targets obtaining the dropable objects by hitTestObject, then the dropable objects visible is turned to false, & the target visible turned to true.
Dragable objects is a 12 elements all of them have an instance names: paper1....paper12.
When I focused to the project I noticed that I forget to give the dragable objects an instance names!
after making the instance names to them, a new error occures:
E:\FL\ActionScript\Drag and Drop Project\Targets.as, Line 11 | 1046: Type was not found or was not a compile-time constant: paper1. |
This error is continuing to paper2, paper3.....paper12 !
Please download my project, I must deliver it to my college in 24/12. I will never forget your favor. thanks.
https://www.dropbox.com/s/8mdg5w17vvryzso/Drag%20and%20Drop%20Project.rar | 715KB
i only download and correct files if i'm hired. free help i only offer via the adobe forums.
aha, I got the point, sorry
no problem.
if you need more help, ask (questions that can be answered in a forum).
I solved the problem.
What did I did ?
* the Dragable objects is a bitmap objects I converted them to MC.....etc .
these bitmaps... I make them Break Apart & then convert them to MC & give them the same instance names, and it works 100% fine
