I inadvertently copied too much data from one FM document to another. I discovered that I did this only after making further changes in the second document, so I was unable to undo the copy/paste operation. Deleting the unwanted text has left my document with more than 80 empty pages that I am unable to delete.
i tried copying only the text I still needed from the second document, deleting everything in the document, and pasting the needed data back in, but the empty pages persist.
How do I solve this problem?
Try:
Special> Delete Pages should do it.
Yes, I found that described on another post. It worked. Thanks.
> Special > Delete Pages should do it.
Let's chat about that.
I've seen cases where if you delete too many trailing pages, and end up deleting pages that still have content, that content is still there, but can be tricky to recover, as it flows out of sight at the bottom of the last remaining page.
The delete pages operation seems almost to mark the new last page as disconnected. A quick search on the DP topic doesn't seem to get any hits on this.
And unrelated to S>DP, if the technique I posted doesn't work, chances are there's some other problem in the document (such as disconnected pages) that requires remediation. It does fix two common problems, which are:
