Plugin loses some actions in progress
Dec 22, 2013 5:00 AM
Please, help me!
I perform certain actions within its handler menu goМenuItem - delete some objects; do other invisible; run through certain actions by PlayActionEvent(), e.t.c. then export the file again through PlayActionEvent("adobe_exportDocument" ...) and see that after all my activities were canceled - a document recovered to the initial state, and after each export and save the need to repeat the entire sequence again. Moreover, on some computers to export certain actions randomly do not work. What am I doing wrong? Sorry for my bad English
    Jan 2, 2014 5:23 AM   in reply to _MBK_
    When you run the action, you're obviously executing the same code that Adobe does when they do it through the UI. One thing I've noticed is that a few of the 'Save As' operations seem to run undo as one of their last steps. Presumably because while they're doing their export work they do some things to the artboard and have to put it back the way they found it. There isn't an easy way to avoid this unfortunately; mainly you just have to notice it and work around it.
    Jan 2, 2014 11:14 AM   in reply to _MBK_
    Yes, I should have said we've noticed it outside of actions too. Basically, you just have to work around it the hard way. In the example code you described, I'd just re-delete my artwork afterwards. It's very annoying, but there's no way around it that we've found.
