pageisking
Elements 12 open RAW
Dec 24, 2013 12:04 AM
Tags: #raw #elements #12
Hi
Used Elements 10 and could open Lumix DMC-FZ200 RAW files but now upgraded to Elements 12 and file is not supported. Have been to updates and have the latest but cannot see the plug-in for RAW files.
Disappointing I have wasted time on this so hope someone can help
Merry Christmas
    Dec 24, 2013 12:27 AM   in reply to pageisking
    You must have converted the files to dng to use in pse 10?
    Anyway adobe says at least camera raw 7.2 is needed for those files:
    http://helpx.adobe.com/creative-suite/kb/camera-raw-plug-supported-cam eras.html
    Pse 12 should open them.
    What operating system are you using?
    If in the pse 12 editor you go to Help>About Plug-in, do you see camera raw listed and if you click on the word camera raw, what version does it say?
    (mac pse 12 would be Photoshop Elements Editor>About Plug-in>Camera Raw)
    Dec 24, 2013 10:37 AM   in reply to pageisking
    I would uninstall and reinstall PSE12.
    Dec 26, 2013 2:11 AM   in reply to pageisking
    When in the editor and you select Help -> About plig-in, does it look anything like this - are the other plug-ins there?
    Brian
    Dec 26, 2013 5:22 PM   in reply to pageisking
    You might try updating using the manual process, here, using what you extract from the ACR 8.3 CC setup.zip found at the following #notconnected link:
    http://blogs.adobe.com/crawlspace/2011/03/keeping-photoshop-up-to-date .html#notconnected
    Instructions for installing manually, just change your source for the plug-in to the setup.zip and the version of Elements to 12:
    http://forums.adobe.com/message/4994243#4994243
    Dec 26, 2013 6:39 PM   in reply to pageisking
    Also, check to see if a camera raw plugin is actually installed by going to:
    C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\Elements 12\File Formats (64 bit windows 8.1)
    or
    C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 12\File Formats (32 bit windows 8.1)
    and see if there is a Camera Raw.8bi in the folder.
    Dec 26, 2013 10:20 PM   in reply to pageisking
    That could be, since the instructions were based on a camera-raw updater made specifically for PSE, while the setup.zip you downloaded had both 32-bit and 64-bit plug-ins for Photoshop.
