Missing Library Content.
Dec 26, 2013 12:26 PM
Hello Everyone.
Ok, I have already Installed CS6 Functional Content, and I have Downloaded the, Encore Missing Content file.
The file is called en-US, If I just copy the en-US into the Adobe Encore CS6 Folder Nothing happens.
So, I think I have to copy the whole contents of the en-US folder Into the Adobe Encore CS6 folder.
I noticed Inside the en-US Folder there are 5 folders as follow: Library, main, Styles,Support,Template.
I noticed there are same folders in the Encore CS6 folder, In other words if I copy past them, it will replace the older files. Should I do that ?
Thanks..
    Dec 26, 2013 12:29 PM   in reply to animationlife
    There are two or three download links in http://helpx.adobe.com/encore/kb/encore-cs6-installed-cc.html or in the links inside that page
    When you are done, you will have (for Windows... you should always give your operating system when asking a question)
    -be sure to follow ALL instructions, including ALL of the download instructions
    -that are contained in the site link INSIDE the link above, or you will not get
    -ALL of the Encore content (download PPro/Encore and then TWO more downloads)
    You will then have (for Windows)
    C:\Program Files\Adobe\Adobe Encore CS6\Library
    C:\Program Files\Adobe\Adobe Encore CS6\Library\Corporate
    C:\Program Files\Adobe\Adobe Encore CS6\Library\Education
    ...and so on for all of the folders
    Dec 26, 2013 1:13 PM   in reply to animationlife
    You have all the files you need. The en-US is what is inside the final download/extraction.
    That is actually a good question. For the library, copy away. And for the others, it does not appear to matter. But, for example, with styles, the styles you have in your styles folder now were installed by the .exe that installed some Encore and Premeire Pro styles, templates, etc. In the Encore en-US styles, you will see some with .psdloc extensions, rather than .psd extensions. When you copy those, the ones with .psdloc will not work. But they are all (I think) already in the styles folder. Copying over them will not replace the ones that were previously without the .psdloc. I don't really know how all this works. It still looks like this is a mess.
    But put the library where they go, and you will have the content you need.
