Error Compiling Movie: Unknown Error
Dec 26, 2013 1:40 PM
Tags: #error #movie #unknown #compiling
I updated my Adobe production premium suite in November 2013. Ever since then I cannot render or export ANY of my projects in Premiere PRo CS6.
ALL of my clips (quicktime h.264) playback fine in CS6, but the moment I add an effect, like color correction, it does not render.
Furthermore, when I make adjustments to the effects, like color corrector, it doesn't reflect any of the changes on the waveform display.
Whenever I render I get this message:
"Error compiling movie: unknown error."
I've tried this with multiple clips/projects but to no avail I get this message Help plzzzz.
    Dec 26, 2013 1:47 PM   in reply to SarahJane000
    First lauch Premiere while holding down shift + alt then clear out media cache database.
    See if that will get it to work.
    Suggestions for error compiling movie:
    http://kb2.adobe.com/cps/906/cpsid_90670.html
    Dec 26, 2013 5:49 PM   in reply to SarahJane000
    Do you have GPU acceleration enabled? If so, please try switching Renderer to Software-only (File>Project Settings>General). This is just a test to isolate the problem.
    Also does encoding fail both when you select Export in the Export Settings dialog (which encodes "in-process") and when you select Queue (which sends the job to AME).
    Dec 27, 2013 5:19 AM   in reply to SarahJane000
    You will have to narrow it down.
    Export a small portion and turn on Preview in AME.
    Watch this and see on which frame/clip or whatever it fails.
