CS4 Indesign crashes when sending to print on Mavericks OS 10.9.1?
Dec 26, 2013 11:20 PM
Does anyone know of a fix for this?
EH
    Dec 27, 2013 1:12 AM   in reply to Elizabeth H
    Mavericks is not a supported OS for CS4 which is now years old, so you are basically on your own with getting it to work. I can tell you that ID does not respond well to in-palce OS upgrades or migration, and I don't know if CS4 will install clean on Mavericks. As a work around I would export to PDF and print that.
    Jan 6, 2014 3:44 PM   in reply to Elizabeth H
    Did you ever find a fix for InDesign crashing? I just upgraded to Maverick and CS4 InDesign crashes everytime I try to print too!
    Jan 6, 2014 4:18 PM   in reply to MikeMalone
    CS4 is unsupported under Mavericks and if that was an upgrade install it’s even more of a crapshoot.
    Feb 1, 2014 1:19 PM   in reply to Elizabeth H
    Hi Elizabeth,
    I had exactly the same problem. Applied all the Acrobat updates as you described and now Acrobat doesn't ask for a password and I can print from InDesign without going via a pdf.
    Thank you.
    Glyn
    Feb 15, 2014 8:32 AM   in reply to Elizabeth H
    Thanks for the info; this worked for me too! Repairing permissions was necessary for the final step of not needing to enter the pw.
    Many thanks!
