• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Creating Map IDs using HTM File Name
Guest
Dec 27, 2013 Dec 27, 2013
Is it possible to create Map IDs using the File name of the HTM, instead of its Topic Title?
Views
672
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
The MapID part of a CSH call can be anything text you want. It links to a map number to link to the HTM file. Is that what you are asking? If not, please explain a little more of what you are trying to achieve.
Votes
Translate
Translate
Report
Report
Guest
While Generating Map IDs, we get an ID along with a Map # for each HTM in the CSH.
For Example, I have a HTM in my CSH with the following Details:
Topic Title - Access Masks
File Name - admpr00001.htm
Now when I create a Map ID for this page. I can customise the Map ID by setting any/all of the three options: - 'Prefix Map IDs with', 'Make Uppercase' and 'Start Numbering with'. But the Map ID is generated only based on the Topic Title.
Like - ebACCESS_MASKS 1000   where, eb is the set prefix.
Is it possible for me to create a MAP ID using the File Name. In this case, as ebadmpr00001 1000?
Hope I am clear .
Votes
Translate
Translate
Report
Report
LEGEND ,
Yes it is. Just set the prefix to eb and create the mapid the way you want.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 30, 2013 Dec 30, 2013
LATEST
RoboColum(n),
I think misk0105 wants to auto-generate IDs for all topics at once using the file name, by highlighting all topics and clicking Auto-map. Of course one could type in the ID manually.
The way the Auto-map works in my instance (RH10) is to assign the topic name. The help says "By default, the application assigns the topic title or filename as the topic ID and assigns a map number," but where can you change it to use the filename?
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
