greenemister
Cannot open mpg files with Audition 6.0
Dec 28, 2013 10:57 AM
Says they are corrupt, but Adobe Premier has no problem with opening them. I was able to only open one real small file. Any ideas?
    Dec 28, 2013 1:16 PM   in reply to greenemister
    Is it saying specifically that the file is corrupt? Or is it saying "...either corrupt or using an unsupported format"?
    Dec 28, 2013 5:12 PM   in reply to greenemister
    Ok, so it sounds like Audition doesn't support the video or audio codec used in your MPGs.
    What are you trying to do with the file? Do you want to add your own audio to the video? Or do you want to save the audio separate from the MPG?
    Dec 30, 2013 12:48 PM   in reply to greenemister
    Have you tried Premiere Pro's "Edit in Adobe Audition" feature? This should be a quick way to get the audio into Audition so you can remove the hum.
    "When applying the Edit In Audition command to clips in a sequence, Premiere Pro renders the audio into a new audio clip that is imported into Adobe Audition."
    http://help.adobe.com/en_US/premierepro/cs/using/WS367138A8-E5E3-49f3- 8719-0EFDC91D329C.html
    "how to send a sequence from Premiere Pro to Audition or how to send a completed mix from Adobe Audition back to Premiere Pro"
    http://www.youtube.com/watch?v=L3F0s8oJKmk
    Dec 30, 2013 7:28 PM   in reply to greenemister
    That's great John. Have an excellent New Year!
