• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Delete items unchecked from a form
New Here ,
Dec 28, 2013 Dec 28, 2013
I have a list from query that populate checkboxes (checked) in a form.
However, when a user deselects some of the items from, I want them to be deleted from the database for that user.
Here is the ex: this is how the form looks like:
                                         Category
Item                                  80      626
1. HS # 1 (87)                   chk    chk
2. HS #2  (59)                   chk    chk
This is the list of items already n their preferences (db ids)
80|87,  626|87,   80|59,   626|59
Now from a form, if they deselect one of the items (80|87), I want it to be deleted from the database.
Like these, DELETE FROM ITEMS_TBL WHERE ITEM_ID = 80, Category_ID = 87
How can we do it? Can we check ListContains or something else?
Views
1.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Dec 29, 2013 Dec 29, 2013
Let's say your query contained 5 records, ID's 1-5.  When output, the user unselects ID 2 and 5.  When they submit the form, you want to delete IDs 2 and 5 right?  But since they are not selected, their IDs are not available in the FORM scope, correct?
What I would do is run the same query on submit, but add an addendum that uses a ValueList() on the FORM variable that holds the selected IDs.  Like:
SELECT
ids,
WHERE ids NOT IN (#FORM.ids#)
That would basically get you back a query of record IDs that are up for deletion.  Then you could run another query right after it that goes:
DELETE FROM tableName
WHERE IDs in (#ValueList( firstQueryName.ids )#)
Votes
Translate
Translate
Report
Report
Explorer ,
it would be a lot easier to do it the other way round, have a checkbox for records you want to be deleted.
Or have a delete button and do it realtime in ajax.
If you really do want to do it this way, then have some javascript that detects when boxes are unchecked, and adds their values to a hidden form field, then you have a list of the records to be deleted.
Votes
Translate
Translate
Report
Report
Enthusiast ,
The only issue with using a hidden form field is that users can modify this value before it is submitted.  So you'll have to do extra cross checking to ensure that the IDs that are there are ones that were initially displayed or that the user had access to delete regardless.
Votes
Translate
Translate
Report
Report
Explorer ,
Aegis, anyone can modify checkboxes or indeed any form field if they feel so inclined, so that is completely moot.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Not at all. Sanity checking all iall forms of input should be par for the course, for whatever solution is chosen.
Votes
Translate
Translate
Report
Report
Explorer ,
Aegis, sorry but you are wrong, all/any form field can be edited before submission, a hidden form field is no different to any other. There are even browser plugins which do it for you, you should most definately check up on this if you think it is not possible.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Dec 30, 2013 Dec 30, 2013
Actually, no, I'm not wrong.  My suggestion is to do sanitization checks on all incoming data BECAUSE client-side data can be modified.  My suggestion is to not take the data presented at face value, but to ensure you always double check that what is provided is valid.  Nowhere in my post do I say that it's not possible.  My hint indicates that just because you put it into a hidden field, does NOT mean that it cannot be messed with before it is sent back to the server.  Many developers have a mindset that hidden data is not exposed to the user for modification as easily as an input field.
Votes
Translate
Translate
Report
Report
Explorer ,
Aegis, you said "QUOTE"
My reply was that this can be done with ANY form field, not just hidden.
You then said: "Not at all."
Votes
Translate
Translate
Report
Report
Enthusiast ,
LATEST
If you're going to quote, quote the WHOLE post.  Because the second line "So you'll have to do extra cross checking to ensure that the IDs that are there are ones that were initially displayed or that the user had access to delete regardless." is the subject behind my reasoning.
It does not state that putting information into a hidden field is not a possible solution.  It just iterates that checking that data before assuming it is processed is a wise course of action, as many new developers often make the assumption that a hidden field cannot be modified.
Votes
Translate
Translate
Report
Report
Resources
Documentation
