Oli-Ver
Trouble installing Adobe Flash Player 11.9.900.170 on Mac OS X 10.9
Jan 2, 2014 4:10 AM
Hello dear experts,
since the last update of Adobe Flash Player I cannot install the application anymore.
The installation cancels with a general error message.
Mac's console shows the following messages:
02.01.14 12:34:21,000 kernel[0]: hfs: mounted Adobe Flash Player Installer on device disk1s2
02.01.14 12:34:21,028 mds[430]: (Normal) Volume: volume:0x7fe19c00f000 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/Adobe Flash Player Installer
02.01.14 12:34:30,703 launchservicesd[444]: Application App:"Install Adobe Flash Player" asn:0x0-55055 pid:1048 refs=7 @ 0x7fd968e4f4d0 tried to be brought forward, but isn't in fPermittedFrontApps ( ( "LSApplication:0x0-0x56056 pid=1051 "SecurityAgent"")), so denying. : LASSession.cp #1481 SetFrontApplication() q=LSSession 100004/0x186a4 queue
02.01.14 12:34:30,704 WindowServer[476]: [cps/setfront] Failed setting the front application to Install Adobe Flash Player, psn 0x0-0x55055, securitySessionID=0x186a4, err=-13066
02.01.14 12:35:39,000 kernel[0]: hfs: could not initialize summary table for Flash Player
02.01.14 12:35:39,000 kernel[0]: hfs: mounted Flash Player on device disk2s2
02.01.14 12:35:42,000 kernel[0]: hfs: unmount initiated on Flash Player on device disk2s2
02.01.14 12:35:45,384 sudo[1106]:   oliver : TTY=unknown ; PWD=/ ; USER=oliver ; COMMAND=/usr/bin/open http://get.adobe.com/flashplayer/completion/aih/?exitcode=1&type=insta ll
If I install with the -debug option with the offline installer Mac's console show the following:
02.01.14 12:54:15,663 launchservicesd[444]: Application App:"Adobe Flash Player Install Manager" asn:0x0-71071 pid:1586 refs=7 @ 0x7fd968e687f0 tried to be brought forward, but isn't in fPermittedFrontApps ( ( "LSApplication:0x0-0x72072 pid=1591 "SecurityAgent"")), so denying. : LASSession.cp #1481 SetFrontApplication() q=LSSession 100004/0x186a4 queue
02.01.14 12:54:15,663 WindowServer[476]: [cps/setfront] Failed setting the front application to Adobe Flash Player Install Manager, psn 0x0-0x71071, securitySessionID=0x186a4, err=-13066
02.01.14 12:54:15,944 authexec[1593]: executing /usr/sbin/chown
02.01.14 12:54:16,008 authexec[1594]: executing /bin/chmod
02.01.14 12:54:16,069 authexec[1595]: executing /bin/chmod
02.01.14 12:54:16,518 authexec[1598]: executing /bin/chmod
02.01.14 12:54:16,633 authexec[1599]: executing /bin/rm
02.01.14 12:54:17,929 authexec[1600]: executing /Library/Application Support/Adobe/Flash Player Install Manager/fpsaud
02.01.14 12:54:17,930 Flash Player Install Manager[1586]: Unable to execute privileged task.
02.01.14 12:54:21,628 mds[430]: (Warning) Volume: vsd:0x7fe19d0c0800 Open failed.  failureCount:5 {
    DisabledRecycleCount = 5;
If I try to start the installation using the Adobe Flash Player.pkg in the „Resources“ folder I cannot chose my hard drive to install flash.
The following log messages can relate to this:
02.01.14 12:59:16,100 Installer[1641]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
02.01.14 12:59:16,101 Installer[1641]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
02.01.14 12:59:16,132 Installer[1641]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
02.01.14 12:59:16,133 Installer[1641]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
I think this exception is thrown if I click on my hard drive’s symbol in the installer.
I have the same problem when I try to install Microsoft’s last Office update. Maybe there is a connection?
I tried several older versions of the Adobe Flash Player installer, but they didn't work as well.
Perhaps we have some kind of "Mavericks" problem here?
Any help would be highly appreciated!
Thank you very much in advance.
Kind regards
Oliver
    Jan 2, 2014 11:13 AM   in reply to Oli-Ver
    The latest Flash player is 100% compatible with Mavericks. I have it and have had it since the morning Mavericks was released, with no problems in Safari, Opera, or Firefox.
    The fact that you have problems installing Office updates as well, indicates you have either a disk permissions error or something went wrong with your Mavericks install.
