• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Is RoboHelp 7 compatible with Windows 8 64-bit?
New Here ,
Jan 02, 2014 Jan 02, 2014
Is Robohelp 7 compatible with Windows 8 64-bit?
Views
735
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
RoboHelp 7 was released many years ago and was more than likely only tested up to Windows XP. Depending on what you are trying to do, you may be OK. You should certainly be able to install RH7 and use it, but if you have issues you will not be supported by Adobe. You can post any issues here, but if we can't help you'd be on your own.
It would be better to update to the latest version. There are many new features that have been added to RoboHelp since version 7.
Votes
Translate
Translate
Report
Report
Explorer ,
Jan 14, 2014 Jan 14, 2014
LATEST
Hi Waltw1207,
I use the original Technical Communication Suite (FM8 + RH7). With all the necessary patches installed, it worked perfectly for years on XP. This is not the case on Win 8 (64-bit). I tried everything to get it working in the new OS environment - but to no avail.
My solution was to install an Oracle VM VirtualBox. I set it up as follows
-  4 CPUs (I have an i7 in the PC)
-  4GB RAM
- Windows XP
Then I installed the TCS in this VM environment. It works brilliantly. No more problems with FM and RH, plus I can run other 64-bit applications on the host machine.
Hope this helps
P.S. If you decide to go down this road, remember to deactivate your application before you install it in the VM environment.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
