Opening an image in Camera Raw from Bridge
Jan 5, 2014 6:05 PM
Tags: #raw #bridge #camera #cc
I recently installed CC.  In Bridge preferences>behaviour, I enabled double clicking on image to open in Camera Raw.  That doesnt work.  Also when I go to File>Open with, Camera Raw is no longer a choice. Has that been disabled in CC?
    Jan 5, 2014 6:56 PM   in reply to margolisr
    What format are you trying to open?  Double click should open a raw image.  Open with only works with jpeg and tiff if you have it set up in edit/camera raw preferences.
  • Omke Oudeman
    Nov 27, 2004
    Jan 6, 2014 2:02 AM   in reply to margolisr
    What applications did you install? Camera Raw is part of PS CC and Bridge uses this plug in also.
    Be sure to have all the updates applied and like Curt stated, provide more details about the file format, camera type and what system you use.
    Jan 6, 2014 5:07 PM   in reply to margolisr
    If you double click on the cv2 file what happens?
    Jan 6, 2014 7:28 PM   in reply to margolisr
    That is not possible, unless it opens in camera raw of photoshop.  Otherwise it is not a raw image such as a .nef, .cr2, etc.  A raw image needs camera raw to open.
  • Omke Oudeman
    Nov 27, 2004
    Jan 7, 2014 2:10 AM   in reply to Curt Y
    Unless you hold down the shift key to bypass the ACR window and open directly in PS…
    But yes, I agree, it seems not the normal route for a raw file.
    Also using both Bridge and LR together is not the best workflow.
