Qizhi Zhang
Incorrect size of TextureAtlas using "Generate Sprite Sheet..."
Jan 6, 2014 6:07 PM
Tags: #spritesheet #textureatlas
1. create a shape of any size. a 4*4 rectangle for example
2. using "Generate Sprite Sheet..." to make a TextureAtlas
3. check the generated config file, the size is wrong: "<SubTexture name="Symbol 1 instance 10000" x="2" y="2" width="5" height="4" pivotX="0" pivotY="0"/>"
width should 4, not 5.
Both Flash Pro CS6 and Flash Pro CC have this bug.
    Jan 6, 2014 9:30 PM   in reply to Qizhi Zhang
    Hi Qizhi
    Can you try this. Round of the  X and Y position to a whole number on the stage.
    Example . Make X = 335 and Y = 54 for the symbol on stage.
    Let me know if this helps.
    Reagrds
    Avinash
