my websites homepage has basically disappeared.
Jan 8, 2014 2:21 PM
Tags: #help_me_please
this is what it should look like.
this is what it looks like when i upload it to my schools server
if you highlight the hompage you can see some of my text. which i had a lot more but it cut it off
Here is the URL:
http://www.usd223.org/pages/HanoverFBLA/3OH3/homepagefinal.html
    Jan 8, 2014 2:22 PM   in reply to tytrackstar15
    Code errors might explain this.
    CSS - http://jigsaw.w3.org/css-validator/
    HTML - http://validator.w3.org/
    Nancy O.
    Jan 8, 2014 3:42 PM   in reply to tytrackstar15
    There is a remote possibility of an FTP error, but the likelyhood is that there is an error in your html syntax. The browser renders as much as it can, and then stops where it cant go any further. The point that its stopping at though will give you a likely clue as to where the error(s) are.
    If you cant find them, upload the code and someone here might be able to have a glance at it for you.
    Jan 8, 2014 4:06 PM   in reply to tytrackstar15
    You page does not validate. For a start, you have TWO <title> tags in your <head>. You also have unclosed elements.
    Do what Nancy told you to do, and validate and correct your html and css code first.
    And the other two pages contain all sorts of errors as well. Fix those first in your code.
    Jan 8, 2014 7:56 PM   in reply to tytrackstar15
    I cant see any unlosed elements (except for the fact that the souce code stops mid <p>)
    There are definitely 2 <title> elements - although this is not causing your problem.
    Can you post up the full source code? I expect there will be errors in your code that can be fixed.
    Jan 11, 2014 12:30 PM   in reply to tytrackstar15
    What exactly is your question and why are you posting all that code into this forum?
    We've already told you that your site contains code errors.  Once those errors are fixed, your page content should re-appear.
    Nancy O.
    Jan 11, 2014 1:17 PM   in reply to tytrackstar15
    Change
    .Bio {
         color: #FFF;
    to
    .Bio {
         color: #000;
    remove the inline styles align="center" and include all formatting in the css.
    Remove reserved characters btween <p> tags - in particular quotation marks, You can replace them with
    &quot;
    Jan 11, 2014 2:40 PM   in reply to tytrackstar15
    tytrackstar15 wrote:
    I'm sorry you have totally lost me
    The url link you posted http://www.usd223.org/pages/HanoverFBLA/3OH3/homepagefinal.html is missing a lot of code compared to that which you posted in the forum. As has been suggested this is an ftp error where the page code has not fully uploaded. Upload the page to the server again, which will overwrite the page which is currently on the server
    Jan 11, 2014 2:43 PM   in reply to tytrackstar15
    No need to post code if you provide a valid URL.  As you can see from the W3C validation report below, you have 7 code errors.  Fix those and you should be good to go.
    http://validator.w3.org/check?verbose=1&uri=http%3A%2F%2Fwww.usd223.or g%2Fpages%2FHanoverFBLA%2F3OH3%2Fhomepagefinal.html
    Use the validation tool to check the code and fix reported errors on your other pages, too.
    Nancy O.
    Jan 11, 2014 2:50 PM   in reply to tytrackstar15
    i'm not at my school so i can't upload it to the server.
    We'll how do you propose to fix it - you can't until you have access to the server. What's currently on the server is only a proportion of the code so its not in a million year going to view the way you think it should.
    Jan 11, 2014 3:07 PM   in reply to tytrackstar15
    Have you tried a different ftp client to upload the page? Google free ftp clients.
    If you view the page code in your browser you will see that the code is truncated - it ends right here:
    'Best known from their first  single “Don’t Trust Me” from their first actual album Want, which was able to  reach number seven on the Billboard Hot 10'
    Nothing below that.
    Jan 11, 2014 3:19 PM   in reply to tytrackstar15
    Well it's some kind of ftp upload error or server error. This is nothing to do with whether your code validates or not.
    The code you supplied uploads perfectly to one of my servers, as I would expect, its just a file. Now your file may be corrupt so maybe copy all of the code and paste it into another file and try uploading that.
    Jan 11, 2014 3:27 PM   in reply to tytrackstar15
    we did that and i even tried making the homepage over from scratch
    The way to test is:
    1) Try uploading through an alternative ftp client. If you're using the ftp facility in DW its generally a pile of rubbish which should be avoided
    2) Upload the page to an alternative server
    Jan 11, 2014 3:34 PM   in reply to tytrackstar15
    ok i'll tell my advisor that for state. i already turn in the website for districts, but i'm 1 out of 3 people in my event so i already am going to state. Thanks for your help.
    Good luck.........it's down to a technical issue beyond your control.
    I did not check for validation - people have a point about validation but don't get hooked up on it. Just learn to write good enough code - it doesnt have to validate. Code can validate and still not render correctly.
    This issue is not about validation its a technical issue outside of your scope.
    Jan 11, 2014 3:42 PM   in reply to tytrackstar15
    it also could be because my school got a new server.
    Stranger things have happened. I see you have uploaded 2 other pages - presumably they are looking as you want them to look?
    Why the ftp client your using or the server is hanging at a certain point in the upload process for the page in question is a mystery. As I say the code you supplied uploads to my server without any issues and the page looks like you want it to look, your first screen shot.
    Jan 11, 2014 3:53 PM   in reply to tytrackstar15
    two other pages?
    Yes, presumably these 2 pages are part of your website and have uploaded correctly?
    http://www.usd223.org/pages/HanoverFBLA/3OH3/eventschedule.html
    http://www.usd223.org/pages/HanoverFBLA/3OH3/tickets.html
    Jan 14, 2014 5:10 AM   in reply to tytrackstar15
    what type of server did you use?
    nginx.
    If you are NOT using any server language in your pages ie - php, asp, cold-fusion etc I don't think it has anything to do with the server. All servers should display html files.
