• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Cross-refs, images in FM inset broken/missing in RH output
Community Beginner ,
Jan 13, 2014 Jan 13, 2014
TCS 4
Linked FrameMaker book
HTML Help output
In several FM text insets, I have added a cross-reference to a topic outside of the inset.
In the HTML Help output from RoboHelp, some (but not all) of the cross references are broken--they look like links, but the cursor does not change to a pointing finger and no jump occurs when you click.
And although the FM "Heading & Page" cross-refs are set to convert to <$paratext> in RH, the broken HTML Help links retain the "on page x" part of the FM style. Again, other cross-refs in the insets convert correctly and are active. Even within the same inset, some cross-refs convert correctly, and some don't.
Finally, I have some FM insets that have table cells with images in anchored frames (toolbar buttons with descriptions). The images are missing in the HTML Help output.
Are these cross-ref and image issues fixable, or is this a limitation of the FM --> RH integration?
Thanks.
Views
1.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Jan 14, 2014 Jan 14, 2014
There seems to be an internal limit on the absolute path length of the xref’d docs that throws off the FM to RH conversion. I would notice that some of my xrefs would appear as href= links in RH and others would not – all on the same page. I solved most of them by shortening down the path length of the FM files to under 35 characters – that seemed to fix most of them.
There have also been reports in this forum of the “<$paratext>” issue you mention, but I don’t know if there was ever a solution found. Try searching for “paratext” to see the threads.
Votes
Translate
Translate
Report
Report
Feb 04, 2014 Feb 04, 2014
So are you saying is that the "workaround" for this is to change all of file names in the FM book, thus breaking who-knows-what as collateral damage? That I will have to rebuild the existing project so that all file paths come in at under 35 characters?
Is this fixed in TCS 5?
Votes
Translate
Translate
Report
Report
Community Expert ,
I ended up just moving the content folder up a few levels to get it shorter – that way it kept all the xrefs the same relative to one another & I didn’t end up breaking any links. I haven’t had time to move up to TCS5 yet & since I was only on the RH11 beta and not the FM12 one, I didn’t get my usual chance to run content through as a test.
Votes
Translate
Translate
Report
Report
I tried that, and it didn't work.
Couple of questions:
1) In the Conversion Settings dialog box, in the RoboHelp Style option settings, there are six instances of the <$paratext> style. The Heading and Heading & Page cross-ref styles from FM both map to the first instance of <$paratext> in the list of styles. Where did the <$paratext> instances come from? What do they correspond to? Why are there six of them?
2) When I click the Help button in the Conversion Settings dialog box, the following topic follows the "Convert FrameMaker cross-reference formats to RoboHelp styles" topic:
Content reference
Text or files that you have inserted into the FrameMaker documents as content references appear as part of the topics where they are referenced. They do not appear as references in the online Help outputs.
I'm not sure what "content reference" means. To me, it's not conventional FM terminology.
Is this (vaguely-worded) statement trying to say that text insets are not supported in HTML Help output?
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 05, 2014 Feb 05, 2014
I think this guy has just discovered what that help text means - http://forums.adobe.com/message/6088014#6088014
Votes
Translate
Translate
Report
Report
Community Expert ,
I’m not seeing the paratext instances you’re talking about – my defaults are all – I have to change them to paratext by typing overtop the Source wording.
Votes
Translate
Translate
Report
Report
LATEST
I moved this discussion to a new thread:
http://forums.adobe.com/thread/1399277
It aggregates info from several other threads and lists several apparent conclusions about text insets and other "content references".
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
