how can you join multiple masks into one???
Jan 14, 2014 10:21 AM
I want to make a video of a self sketching pen as the uploaded video. To do that i thought of making a vector  of the  image that i want to sketch from illustrator and copy that as a mask to AE then use it to add stroke effect with reveal original image. Then use the mask path of same masks to move the pen layer so it writes along while moving the pen .but the only problem is since there are several maks i cant copy and paste mask path data to the position attribute  of the  pen layer. i mean i can but then i have to use key frames. but when there are lot of masks it is a pain in the neck !! so if there is a way that i can join all the mask into one mask then its an easy job!! Is  there any way you can join multiple masks or is there any other way to make this kind of a video??
    Jan 14, 2014 11:42 AM   in reply to Dlikzrox
    Three questions:
    Do you really mean "self-sketching pen", or can a hand be attached to the pen, as in the example video?  There's a big difference.
    Have you downloaded the example video to scrutinize it frame-by frame to see just what they're doing?
    Do you have at leaswt an intermediate-level knowledge of both Illustrator and After Effects?
    Jan 14, 2014 4:51 PM   in reply to Dlikzrox
    I strongly recommend looking VERY closely at that video; I think you'll find that by looking at it frame-by-frame, you can see a bunch of shortcuts they took that you can also take advantage of.
    If you're not that strong in Illustrator, I assume you'll be using an image that's already drawn... in which case, you may be in for some tricky masking rather than how you initially proposed to pull off this look.... a process that could be made easier by scrutinizing the example video
    Jan 14, 2014 7:32 PM   in reply to Dave LaRonde
    If somebody wanted me to recreate that video I'd bill them for 10, maybe 20 hours. You said "but when there are lot of masks it is a pain in the neck !!"  That's right.... Animation takes time and what you are trying to do requires a bunch of time.
    As far as copying and pasting the paths from Illustrator to a mask path in AE, that's easy, and if you select your paths in order and set up the stroke to stroke sequentially then you'll have your reveal.
    Now, start with mask 1, set a keyframe, copy the keyframe.
    Set the anchor point of your hand/pen layer to the tip of the pen. If the pen is moving (like a movie) then you'll have to track the pen tip.
    Now set a single keyframe at the same point in the timeline where the lines are starting to be revealed by the animated stroke and paste. You'll get the motion path for the first path.
    Now move to the end of the first line reveal and grab the last keyframe of the motion path and drag it to the CTI. move forward 1 keyframe, set a new position keyframe, select mask 2, set a single keyframe and copy, go back to your new position keyframe and paste. Adjust again and repeat for the 3 or 400 mask paths you have in the drawing...
    Like I said, 10 or 20 hours even with cheats.
    BTW, in illustrator, if your paths are all open, you can join the end points of paths to make a longer one. If the paths are closed there is no such option.
    Like Dave said, there are lots of cheats in this video. The hand only kind of follows the revealed drawing. I'm sticking with my 10 to 20 hour estimate unless I can see the drawing you're trying to animate.
    Jan 14, 2014 10:37 PM   in reply to Dlikzrox
    As Rick said, aniamtion takes time. just get used to it. There's not a magic button for everything.
    Mylenium
