Hi dear friends
I'm too rusty with flash but today appearl a problem
I have this code is in AS1 and needs to be in AS3...
Is an RSS code with title and description only...
if some one can insert a picture, please tell...
titulo2 and texto2 are drop shadows
System.useCodepage = true;
loadNum = new Loadvars();
loadNum.onLoad = function (ok)
var __reg1 = _root;
if (ok)
__reg1.titulo.text = __reg1.loadNum.titulo;
__reg1.titulo2.text = __reg1.loadNum.titulo;
__reg1.texto.text = __reg1.loadNum.texto;
__reg1.texto2.text = __reg1.texto.text;
loadNum.load("rssnews.dat");
trace(numPics);
titulo2 and texto2 are textfields or your as1 code is incorrect. (however, they may appear to be dropshadows because of offset and alpha manipulations.)
var urlLoader:URLLoader = new URLLoader();
urlLoader.addEventListener(Event.COMPLETE,completeF);
urlLoader.load(new URLRequest("rssnews.dat"));
function completeF(e:Event):void{
var __reg1:MovieClip=MovieClip(root);
__reg1.titulo.text=XML(urlLoader.data).titulo;
etc
etc
ok I tried but still not working
now I deleted that text that appears like dropshadows
__reg1.texto.text=XML(urlLoader.data).titulo;
but the text doesn't appear...
use the trace function to debug:
trace(XML(urlLoader.data));
paste the (first 50 or so lines of) trace output in this forum.
Ok, thanks but now appear another BIIIIIIG problem...
the situation is it:
I have a led painel and in his playlist have a very very old rss reader ( I can't change it ), and it read from a .FLA AS1 ( in flash player 6 )
flash player 6 doesn't run videos in .flv as background... So I exported the .swf in flash player 8 but appear this erro
output - undefined
Compiler errors - The identifier 'Loadvars' will not resolve to built-in object 'LoadVars' at runtime.
my action frame
var __reg1 = _root;
if (ok)
trace (numPics);
Trying by AS3 it appear the text in the output
titulo=R7&texto=Forças russas enfrentam militantes antes dos Jogos de Inverno; 7 ...&
my code
I just need to put these "titulo" and "texto" from .dat in two separeted dynamic texts (titulo, text)
Hi guys
now I change almost everything and IT WORKED
my new code
var loader:URLLoader = new URLLoader();
loader.dataFormat = URLLoaderDataFormat.VARIABLES;
loader.addEventListener(Event.COMPLETE, loading);
loader.load(new URLRequest("content.txt"));
function loading (event:Event):void {
news_1.text = loader.data.var_1;
news_2.text = loader.data.var_2;
here works fine, but when I repleace my "content.txt" to "rssnews.dat" file to load, it appear
Error: Error #2101: The String passed to URLVariables.decode() must be a URL-encoded query string containing name/value pairs.
at Error$/throwError()
at flash.net::URLVariables/decode()
at flash.net::URLVariables()
at flash.net::URLLoader/onComplete()
use:
loader.dataFormat="variables";
where??
oops, that is the problem. you added that code.
just use the code i suggested which uses urlLoader.dataFormat="text", by default and that is the correct format for reading rss data.
and where i put the dinamic texts ?
news_1.text
news_2.text
copy and paste the first 20 or so lines of that trace output here.
the AS
__reg1.news_1.text = trace(e.target.data.titulo);
__reg1.news_2.text = trace(e.target.data.texto);
The output
ReferenceError: Error #1069: Property titulo not found on String and there is no default value.
at NoticiasRSS_fla::MainTimeline/completeF()
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
use:
var a:Array=e.target.data.split("&");
__reg1.news_1.text = a[0];
__reg1.news_2.text = a[1];
p.s. you may need to caste a[0] etc as a string
Ok now the text appeared
but I don't want to see the "titulo=" and the "texto="
is possible?
thanks
use:
__reg1.news_1.text = a[0].split("=")[1];
__reg1.news_2.text = a[1].split("=")[1];
It WORKED!!!!! You saved my life
Thanks a lot
you're welcome.
