Cbradsh1
Flex AMF Data/Services Error
Jan 14, 2014 2:05 PM
Tags: #flex #blazeds_data_service #blazeds
After stumbling my way through setting up a BlazeDS service, I was finally able to get the list of services through the Flex Builder Data/Services Wizzard.  However when testing any of the services, I get the Error popup of
"InvocationTargetException:There was an error while invoking the operation. Check your operation inputs or server code and try invoking the operation again.
Reason: java.io.FileNotFoundException: http://localhost:8080/portlets-0.0.1-SNAPSHOT/messagebroker/amf
I could not find anyone else with a similiar issue, and am unfamiliar with services setup. Below are my configurations.  Any help would be greatly appreciated.
Thank you.
services-config.xml:
<?xml version="1.0" encoding="UTF-8"?>
<services-config>
          <services>
                    <service id="remoting-service" class="flex.messaging.services.RemotingService">
                              <adapters>
                                        <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
                              </adapters>
                              <default-channels>
                                        <channel ref="my-amf"/>
                              </default-channels>
                    </service>
          </services>
          <channels>
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                              <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                              <properties>
                                        <add-no-cache-headers>false</add-no-cache-headers >
                                        <polling-enabled>false</polling-enabled>
                              </properties>
                    </channel-definition>
          </channels>
          <logging>
                    <!-- You may also use flex.messaging.log.ServletLogTarget -->
                    <target class="flex.messaging.log.ConsoleTarget" level="Error">
                              <properties>
                                        <prefix>[BlazeDS] </prefix>
                                        <includeDate>false</includeDate>
                                        <includeTime>false</includeTime>
                                        <includeLevel>true</includeLevel>
                                        <includeCategory>false</includeCategory>
                              </properties>
                              <filters>
                                        <pattern>Endpoint.</pattern>
                                        <pattern>Service.</pattern>
                                        <pattern>Configuration</pattern>
                              </filters>
                    </target>
          </logging>
</services-config>
messaging-config.xml:
<service id="message-service" class="flex.messaging.services.MessageService">
          <adapters>
                    <adapter-definition id="actionscript"
                              class="flex.messaging.services.messaging.adapters.Acti onScriptAdapter"
                              default="true" />
          </adapters>
          <default-channels>
                    <channel ref="my-amf" />
          </default-channels>
</service>
remoting-config.xml:
    <adapters>
    </adapters>
    <default-channels>
    </default-channels>
</service>
flex-spring-application-context.xml:
<?xml version="1.0"?>
<beans xmlns="http://www.springframework.org/schema/beans"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:context="http://www.springframework.org/schema/context"
xmlns:tx="http://www.springframework.org/schema/tx"
xmlns:p="http://www.springframework.org/schema/p"
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:jee="http://www.springframework.org/schema/jee"
xmlns:flex="http://www.springframework.org/schema/flex"
xsi:schemaLocation="http://www.springframework.org/schema/jee
          http://www.springframework.org/schema/jee/spring-jee-3.0.xsd
          http://www.springframework.org/schema/beans/spring-beans-3.0.xsd
          http://www.springframework.org/schema/context/spring-context-3.0.xsd
          http://www.springframework.org/schema/tx/spring-tx-3.0.xsd
          http://www.springframework.org/schema/aop/spring-aop-3.0.xsd
          http://www.springframework.org/schema/flex/spring-flex-1.5.xsd">
<context:annotation-config />
<context:component-scan base-package="org.amc" />
<flex:message-broker services-config-path="/WEB-INF/flex/services-config.xml"/>
</beans>
Service Class:
package org.amc;
import org.springframework.flex.remoting.RemotingDestination;
import org.springframework.flex.remoting.RemotingInclude;
import org.springframework.stereotype.Service;
@Service("FlexLifeFacadeAnnotation")
@RemotingDestination(channels={"my-amf"})
public class FlexLifeFacade {
          @RemotingInclude
          public String echo(String msg) {
                    return "Message received at " + new java.util.Date() + ": " + msg;
