Cineware - Sketch and Toon
Jan 14, 2014 8:54 PM
I read multiple places that Cinema 4D's Sketch and Toon renderer would be availible in Cineware and useable in After Effects after the 12.2 update. Still can not get it to work.
New rendering capabilities
When you choose to use an edition of Cinema 4D other than Cinema 4D Lite, you can use new rendering capabilities within Cineware beyond the default renderer, including the Physical renderer and Sketch & Toon. To use the new rendering capabilities, do the following:
  1. Choose a different renderer to use in Cinema 4D
  2. Save the .c4d file with the renderer settings.
  3. The renderer specified in Cinema 4D is the one that will be used by the Cineware effect when the Renderer setting in the effect is Standard (Final).
Found this on http://helpx.adobe.com/after-effects/using/c4d.html
The directions imply changing the renderer in render settings. While this may work for the Physical renderer, Sketch&Toon is not a renderer, but an effect.
I also tried applying tags directly to shape, but to no avail. Would love some help! In the middle of a massive project, and need this to work. Thanks!
- Ivan
