Santu
Flex mobile live streaming
Jan 14, 2014 7:27 PM
Tags: #flex-mobile #ios #flex_mobile #actionscript_3.0 #4.6
Hi All,
  I am trying to display a live stream from rtmp server. Below is my code.
<s:Group height="100%" width="100%"
         xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx">
    <fx:Script>
        <![CDATA[
            import mx.core.FlexGlobals;
            private const URL:String    = "rtmp://eigr2.flashlive.bigCDN.com/20175D";//"http://www.helpexamples.com/flash/video/cuepoints.flv";
            private const STREAM_KEY:String = "eigr8";
            private var _video:Video = new Video();
            private var _nc:NetConnection;
            private var _custClient:Object;
            private var _ns:NetStream;
            private var _streamKey:String;
            public function playVideo():void
                var  url:String = URL;
                if(videoHandler.numChildren == 0)
                    _nc    = new NetConnection();
                    _nc.addEventListener(NetStatusEvent.NET_STATUS, netStatusHandler);
                    _nc.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
                    _nc.connect(URL);
            private function netStatusHandler(event:NetStatusEvent):void
                trace("NC " + event.info.code);
                switch (event.info.code)
                    case "NetConnection.Connect.Success":
                        _video                    = new Video();
                        _video.smoothing        = true;
                        var custClient:Object    = new Object();
                        custClient.onMetaData    = metaDataHandler;
                        _ns                = new NetStream(_nc);
                        _ns.client        = custClient;
                        _ns.addEventListener(AsyncErrorEvent.ASYNC_ERROR, asyncErrorHandler);
                        _ns.addEventListener(DRMErrorEvent.DRM_ERROR, drmerror);
                        _ns.addEventListener(DRMStatusEvent.DRM_STATUS, drmStatus);
                        _ns.addEventListener(StatusEvent.STATUS, status);
                        _ns.addEventListener(NetStatusEvent.NET_STATUS, target);
                        _ns.bufferTime = 2;
                        _ns.receiveVideo(true);
                        var net:NetStreamPlayOptions = new NetStreamPlayOptions();
                        //net.len = 1;
                        //net.transition = NetStreamPlayTransitions.APPEND;
                        net.streamName = STREAM_KEY;
                        _ns.play(STREAM_KEY);
                        _video.attachNetStream(_ns);
                        videoHandler.addChild(_video);
                        videoHandler.visible = true;
                        //background.visible = true;
                        break;
                    case "NetConnection.Connect.Failed":    //shownoVideoText();
                        break;
                    case "NetStream.Play.StreamNotFound":    trace("Unable to locate video: ");
                        break;
            private function status(event:StatusEvent):void
                trace("Status Event : " + event.toString());
            private function drmerror(event:DRMErrorEvent):void
                trace("DRM Error : " + event.toString());
            private function drmStatus(event:DRMStatusEvent):void
                trace("DRM Status : " + event.toString());
            private function videoStates(event:Event):void
                trace(event.toString());
            public function stopVideo():void
                _nc.close();
                _nc = null;
                _ns = null;
                this.videoHandler.removeChild(_video);
            private function asyncErrorHandler(event:AsyncErrorEvent):void
                trace("Async errrorrrrrrrrrrrrrrrrrrrr");
            private function target(e:NetStatusEvent):void
                trace("Started playing : " + e.info.code);
            private function metaDataHandler(infoObject:Object):void
                this.setVideoSize(infoObject.height, infoObject.width);
            /*public function playVideo():void
                custClient    = new Object();
                nc.connect(null);
                nc.client = { onBWDone: function():void{} };
                //nc.addEventListener(NetStatusEvent.NET_STATUS, target);
                ns        = new DynamicCustomNetStream(nc);
                ns.play(URL);
                videoPlayer.attachNetStream(ns);
                videoPlayer.smoothing        = true;
                if(!videoHandler.contains(videoPlayer))
                    videoHandler.addChild(videoPlayer);
            override public function set currentState(value:String):void
                super.currentState = value;
                this.videoHandler.percentHeight = value == "fullScreen" ? 100 : 50;
            public function onFCSubscribe(info:Object):void
                trace("onFCSubscribe - succesful");
            protected function goBack():void
                FlexGlobals.topLevelApplication.showVideo(false);
    </fx:Script>
    <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
    </fx:Declarations>
    <s:Button click="goBack()"
              horizontalCenter="0"
              label="Go Back" bottom="50"/>
    <mx:UIComponent width="100%"
                    height="50%"
                    top="0" left="0"
                    id="videoHandler"/>
</s:Group>
When I try to run this, I could successfully connect to server but not getting the data. If I open the url in browser PublishNotify gets dispatched and I get the stream. As soon as I close UnpublishNotify gets dispatched and I wont get the stream. Can I know the possible reasons and solution?
