Is using current date and dateAdd the best way  to show 30 days worth of records .
Jan 15, 2014 1:04 PM
I want to display files from the day a viewer logs in, through the next 30 days. I tried the code below but it does not work. What am I doing wrong?
<cfoutput><cfset mydatetime=#now()#></cfoutput>
<cfquery name="getdevotional" datasource="#application.database#">
SELECT display_date, title
FROM mobile
where display_date BETWEEN (#DateFormat(Now(),'YYYY/MM/DD')#) AND (#DateFormat(DateAdd('d', 30, mydatetime),'YYYY/MM/DD')#)
</cfquery>
    Jan 15, 2014 1:21 PM   in reply to rickaclark54
    Hi Rick,
    Depending on what database platform you're using you could do something similar to the following (My example is using T-SQL for SQL Server 2012)
    SELECT     [m].[display_date], [m].[title]
    FROM        [mobile] AS [m]
    WHERE      [m].[display_date] <= DATEADD(day,GETDATE(),30) AND
                      [m].[display_date] >= GETDATE()
    Hope this helps!
    Jan 15, 2014 2:17 PM   in reply to ColdFusionChris
    Rick,
    Just to clarify what ColdFusionChris is doing there:  the DATEADD and GETDATE functions are SQL Server T-SQL functions.  They are executed as part of the query on the database server (which is why they aren't wrapped in pound signs).
    -Carl V.
    Jan 15, 2014 2:22 PM   in reply to rickaclark54
    Alternatively, use CFQueryParam and get rid of the DateFormat() calls:
    FROM mobile
    where display_date BETWEEN <cfqueryparam value ="#mydatetime#" cfsqltype="cf_sql_date"> AND <cfqueryparam value="#DateAdd('d', 30, mydatetime)#" cfsqltype="cf_sql_date">
    </cfquery>
    -Carl V.
    Jan 16, 2014 9:02 AM   in reply to rickaclark54
    Rick,
    Which code sample are you are trying?  Chris's or mine?
    -Carl V.
    Jan 16, 2014 10:34 AM   in reply to rickaclark54
    Hmmm.  I just tried the same approach on a table in one of my databases, and got back 2014 results.  If you dump your "mydatetime" variable, what does it look like?
    -Carl V.
    Jan 16, 2014 11:31 AM   in reply to rickaclark54
    Uggghhh.  MSAccess SQL may require wrapping your dates in pound signs (#) (I don't have the ODBC services installed on my machine to test this out).  If it does require the pound signs, you have to double them up to escape them from being used as ColdFusion variable outputs.  So I think your query would look like this (again, I can't test this to verify):
    SELECT mob_id, display_date, title, scripture, body
    FROM devotional
    WHERE display_date BETWEEN ##<cfqueryparam value ="#mydatetime#" cfsqltype="cf_sql_date">## AND ##<cfqueryparam value="#DateAdd( 'd', 30, mydatetime )#" cfsqltype="cf_sql_date">##
    If that doesn't work, try this instead:
    FROM devotional
    WHERE display_date BETWEEN ###CreateODBCDate( mydatetime )### AND ###CreateODBCDate( DateAdd( 'd', 30, mydatetime ) )###
    -Carl V.
    Jan 16, 2014 4:22 PM   in reply to rickaclark54
    Is the "display_date" date column actually a Date/Time field in MSAccess?  Or is it a text field?
    -Carl V.
    Jan 17, 2014 2:51 AM   in reply to rickaclark54
    I would stick with the cfqueryparam that Carl suggested. It enables the comparison of like with like. I am thinking along the lines of
    FROM devotional
    where dateValue(display_date) BETWEEN <cfqueryparam value ="#now()#" cfsqltype="cf_sql_date"> AND <cfqueryparam value="#DateAdd('d', 30, now())#" cfsqltype="cf_sql_date">
    Jan 17, 2014 8:55 AM   in reply to rickaclark54
    Rick,
    Glad you got it working.  Anytime you can move a database off of MSAccess onto a more capable RDBMS, it's a good thing.
    Could you kindly mark whichever solution above worked for you as "correct" for future users who might have a similar question?
    -Carl
