How can I see the color of the hex value in a style sheet in DW CC
Jan 18, 2014 2:53 PM
I simply want to click on a hex value (#c1c1c1) in a style and see what color it is. I can't find it anywhere. Please help!
    Jan 18, 2014 3:12 PM   in reply to RichieWhite
    See screenshot from the CSS Designer tutorial.
    helpx.adobe.com/dreamweaver/using/css-designer.html
    Notice where it says color under display?
    http://helpx.adobe.com/dreamweaver/using/css-designer/_jcr_content/main-pars/image_5.img.png/cssdesigner_live2.png
    Nancy O.
    Jan 19, 2014 11:29 AM   in reply to RichieWhite
    Sorry.  Clicking on hex code doesn't do anything.
    In code view CSS, type color: +spacebar.  Code hinting will invoke a window.  Double-click on Color to bring up the color-picker tool.
    Nancy O.
    Jan 24, 2014 6:34 AM   in reply to RichieWhite
    If you want to go back to the old style css editor, hit Ctrl + Option/Alt + Shift +P
    That will turn the CSS Designer back into the old CSS Panel.
    It's not clear why this is an undocumented feature, so there's no telling if it will remain a feature going into newer versions of CC, but as of 13.2 Build 6466 it is available as an option.
    Jan 24, 2014 6:46 AM   in reply to RichieWhite
    I thought some of the answers above felt strange. Why wouldn't DW show you the color of a hex code when you clicked it. So I fiddled around a bit and as far as I can tell, if you click on a hex color within the css of a page (or a css file) the CSS Designer does show you the color.
    When I click on #AF070A in my .css file, it shows the color in the Properties sub window of the CSS Designer panel.
    You have to scroll down a touch, but it's there...
    Jan 24, 2014 9:44 AM   in reply to RichieWhite
    Hello Richie,
    maybe you could use this small detour, I made here. I marked the wished text, wrote the "#c1c1c1" into the field "text color" (translated from my German DW) and clicked "enter". After that DW opened this window (see screenshot):
    Now you can "jump" across the color field or use the slide switches on the right, where you always can see the color and the referred color values in three categories (at two places).
    Hans-Günter
    Jan 24, 2014 12:45 PM   in reply to RichieWhite
    I see two options inside DW:
    1. Right-click on the hex value in the stylesheet > Code Hint Tools > Color Picker
    2. Windows > Assets, click the Colors icon button in the Assets panel for a summary list of colors and hex values used throughout the current website
    Jan 25, 2014 5:28 AM   in reply to RichieWhite
    Hello Richi,
    I see, you cannot live with that! But you could your  "I want to click on a value and see the color ..." serve as suggestion to https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform, where you can
    "Use this form to request new features or suggest modifications to existing features."
    Good luck!
    Hans-Günter
    Jan 25, 2014 9:35 AM   in reply to Jon Fritz II
    Jon's answer is the closest of all. Just one minor change, and it will work perfectly.
    In the Properties pane of the CSS Designer, select the Show Set checkbox. That will eliminate the need for any scrolling. Just click inside the colour in the stylesheet, and the CSS Designer will display a colour box showing you the colour.
    Another technique, but not as effective, is to open the Assets panel, and select the Colors icon. The panel displays all the colours used in the site. They're listed in numerical order.
    Jan 29, 2014 9:13 AM   in reply to RichieWhite
    RichieWhite wrote:
    I think it should say something more intuitive than "show set", whatever that means.
    "Show set" means "Show properties that have been set" (in other words, ones that have values).
