mattdwm 218 posts
Sep 6, 2010
How do you make a rotating circle's edges smooth?
Jan 20, 2014 8:53 AM
This example has a primitive circle and a motion tween. Is there a way to make the edges look sharp? Right now it looks rough.
circle-test.fla
    Jan 20, 2014 9:09 AM   in reply to mattdwm
    Click the circle symbol, in properties enable the Render as Cache As Bitmap. It's a small improvement but it does actually work in HTML mode as well.
    Option:
    Very slight improvement (smoothing/blur).
    Off:
    You can see the subpixels. Turn it on, you can still see the subpixels, although slightly less:
    Depending on your OS setting, you're dealing with 72DPI or 96DPI. This just isn't enough to make subpixels invisible like modern phones and tablets (300DPI+). You'll always see some level of pixellation unless you blur the heck out of the edges and then they'll seem soft.
    Jan 20, 2014 9:53 AM   in reply to mattdwm
    Look at it on a device without the cacheAsBitmap and it may look much better. Try enabling it again and look at it on the same device. The DPI makes all the difference. The pixels are so small the edges won't look pixelated to the human eye.
    Jan 20, 2014 10:08 AM   in reply to mattdwm
    To reinforce what sinous is saying, there isn't anything you can do on a  72 or 96 dpi screen to make the image look smoother than the "Render as Cache As Bitmap" version. The version that is rendered without "Render as Cache As Bitmap" has a minimal amount of anti-aliasing to make it look smoother. The "Render as Cache As Bitmap" has a moderate amount of anti-aliasing and more would only make the image edges look fuzzy.
    Do you have example of the circle looking smoother in any other program such as photoshop on your screen?
    The only thing to make the image look smoother is to render it on a higher resolution screen and use a higher resolution image.
    Jan 20, 2014 5:49 PM   in reply to mattdwm
    Makes sense but it's simply impossible. Here's a screenshot from one of the highest DPI phones on the market from your link. Samsung Note 3.
    http://www.ertp.com/tmp/note32.png
    Posting from mobile now or I'd include it in the post. 386DPI.
    Jan 21, 2014 2:15 AM   in reply to mattdwm
    The scan rate of your display vs. your animation rate also creates a certain amount of "flicker" when animating. Higher scan/refresh rates, higher resolution displays should create less.
