Emily Lee
The play switch failed
Jan 20, 2014 7:00 PM
The play switch has no function, cannot edit or listen to files. Used to be OK.
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jan 21, 2014 1:22 AM   in reply to Emily Lee
    You need to reconnect your sound device to Audition. Go to the Preferences section and Hardware setup, and re-establish it. This is pretty much the only reason that this ever happens....
    Jan 21, 2014 5:33 AM   in reply to Emily Lee
    HI,
    just try to reset the prefrences.
    http://forums.adobe.com/message/4761844
    regards
    karandeep singh
    Oct 26, 2006
    Jan 21, 2014 5:46 AM   in reply to Karandeep
    You may (or may not) have noticed that the vast majority of the information in that link came from me. So I know it's there, and if it contained the solution to this problem, I would have said so. But it doesn't. There is no point in resetting somebody's preferences and all their individual settings unnecessarily , and there's not much chance that it would re-establish playback correctly anyway.
    No, the answer is as I said in the first place - a simple matter of re-establishing the correct playback device from what is hopefully listed in the hardware preferences, and not attempting to fix a load of stuff that isn't broken. The only thing that I would add is that if there isn't anything suitable listed, then strictly speaking it's stopped being an Audition problem. At that point, I would have expected all sound on the machine to have failed.
    Jan 21, 2014 6:28 AM   in reply to SteveG(AudioMasters)
    Right SteveG, The information I shared was coming from your side.
    The problem Emily Lee is facing could be because of the corrupt prefrences that's why I shared that.
    What is actually the problem we cannot determine till the time we have all the information from the Emily Lee we are not even sure which operating system /Audition version and many more information  Emily Lee is using.
    So cannot determine what is the actuall problem and its solution
    Oct 26, 2006
    Jan 21, 2014 7:07 AM   in reply to Karandeep
    Karandeep wrote:
    The problem Emily Lee is facing could be because of the corrupt prefrences that's why I shared that. What is actually the problem we cannot determine till the time we have all the information from the Emily Lee we are not even sure which operating system /Audition version and many more information  Emily Lee is using.
    Not the case at all. We have this happen a lot, and invariably it's the same failure, and it's across all versions and all OS's. It even applies to Macs, for heaven's sake. If just the transport fails, it's because the sound device is disconnected; nothing else gives just that symptom.
    And apart from anything else, we'd always suggest this first anyway. If anything else is wrong, you need it eliminated before you go any further. I have been doing this a long time, and I do know what I'm talking about.
    Furthermore, you wouldn't need to trash all of the preferences anyway - the connection information is in MachineSpecificSettings, so that's the only one you'd need to restore.
    Jan 22, 2014 6:55 AM   in reply to Karandeep
    Yeah, could be corrupt preferences...but this is a question we get all the time on this forum and 99% of the time it's a simple as reconnecting to the interface under Preferences/Audio Hardware.
    If that doesn't work, then it's worth looking at things like a corrupt file...but going straight to that is like going straight to amputation at the knee because somebody has a sore foot.
