BobbyShepherd
Unexpected Change in Eyedropper Behavior
Jan 24, 2014 11:25 AM
Tags: #illustrator #bug #eyedropper #cc #appearance #mixed_appearances
When I select a Text Object and then use the Eyedropper Tool to sample any other type of object, it now applies a secondary set of Fill and Stroke higher in the Appearance hierarchy instead of just changing the Fill/Stroke of the Text Object, creating a Mixed Appearances problem.
I've included a lot of screen grabs. the 00 images are the initial object states.
From there, A is a drill-down use of the Eyedropper tool that produces the correct end result, but now with two more required steps.
B is by just using the Eyedropper, resulting in conflicting double application of Fill and Stroke.
UPDATE: This also occurs when applying to Groups and Compound Shapes.
UPDATE: This also occurs when applying to Layers.
