mschmidt1905
CS6 Batch Saving for Web
Jan 23, 2014 3:35 PM
Tags: #batch_saving_for_web
CS 6 Version 13.0
I have got the following issue:
I did create action to save files of a folder for web. Within the action I have defined the destination folder. So far, everything works fine and the files are saved in that folder in much smaller size.
BUT:
When I configure the automation choosing a new destination folder and renaming the files, the following occurs:
- Files are saved in the new destination folder  OK
- File size in new destination folder is much bigger compared to file generated by saving to destination folder defined within action !??
Can anyone help me out?
    Jan 23, 2014 6:33 PM   in reply to mschmidt1905
    Since File>Save for Web is an export plugin, the files are always saved to the folder path you used when recording the action.
    The destination in Automate>Batch doesn't change that.
    You would set the Destination to None.
    You might fiind it easier to use the Image Processor Pro rather than an save for web action.
    (included in Dr. Browns Services 2.3.1)
    http://www.russellbrown.com/scripts.html
