Sweko
Data Objects in New Dreamweaver
Jan 23, 2014 6:28 PM
Hello,
I am trying to create a Recordset Navigation Bar.
I first attempted this by doing the following: "Select Insert > Data Objects > Recordset Paging > Recordset Navigation Bar."
The problem I am having is that I cannot reach the "Data Objects" stage.
When this did not work, I attempted the following:
It can be found at "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CC\configuration\DisabledFeatures".
Install the file named "Deprecated_ServerBehaviorsPanel_Support.zxp" using Extension Manager CC.
I was hoping that the "Data Objects" would be in the Windows bar after installing the extension. Unfortunately, it still was not.
If there is no way to re-install the "Data Objects" section in the Windows bar, how else would you recommend making a Recordset Navigation Bar"?
Thank you!
    Jan 24, 2014 6:29 AM   in reply to Sweko
    Hi Sweko,
    This discussion probably contains what you are looking for http://forums.adobe.com/message/5434675. Do get back to us if you need more information.
    Preran
    Jan 24, 2014 10:45 AM   in reply to Sweko
    I think you may be stuck with downloading and installing DWCS6 to get that option...
    http://helpx.adobe.com/creative-cloud/kb/download-previous-versions-cr eative-applications.html
    Both DWCC and DWCS6 can be installed at the same time by Creative Cloud Subscribers, they just won't run at the same time.
    I know it's a pretty lame work around, but might do the trick none-the-less.
