Hello,
When you select ToC in Overlay + Right mode, it won't appear properly : it will appear and slide OUT of the frame instead of sliding in !
I could reproduce the behaviour on a fresh Cp7 version. It's not straightforward, though, you may have to play a bit with the settings to get the behaviour.
I don't know if there's a workaround...
As you can see in the animation above, you have to use the twin arrows button to bring back a normal behaviour.
PJ
Hello,
Ideally it works but could you also tell me the settings which you have changed which is causing this problem.
Thanks and Regards
HImanshu Satija
Hello Himanshu,
I just changed what I describe in the first post :
- overlay
- appear from right
Here's another variation of the bug :
Could somebody be kind enough to try and reproduce the bug so I can submit this to Adobe ?
It takes 10 seconds to set up !
Thanks !
I tried but I cannot reproduce your bug. I'm on Win7 with Cp 7.0.1
Thanks for trying !
After further testing, it has to do with the project width and I think, calculation of the slider's horizontal position.
640x480 will be OK.
Put 1019 as width (resize project) and you get the behaviour shown in the animation
Put 900 and you get another behaviour.
Anyone for another go with the test values I gave above ?
Thanks !
