Dreamweaver CC Mac OS X slow like a tortoise
Jan 26, 2014 6:42 AM
Tags: #dreamweaver #slow
Hi
I'm on a high end Mac Pro early 2008 full of RAM under Mac OS X 10.8.5. Don't know why Dreamweaver CC is so slow to open a file. Anytime get the multicolor circle and need 10 to 20 seconds to open any file. Dreamweaver is useless in my case and nothing fix this problem. Delete cache, restart, re-configuration of everything. Install updates. Nothing works. Dreamweaver CC is tortoise. Any idea?
Thanks.
Tom
    Jan 26, 2014 12:45 PM   in reply to Tom Adobe
    Is this happening with all sites & all files or just a few?
    Is this happening with a new, blank document?
    If not, I'm guessing you have references to external JavaScripts that are slowing you down.  Try commenting them out to see if this improves performance.
    Nancy O.
    Jan 27, 2014 6:01 AM   in reply to Tom Adobe
    Hi Tom,
    Can you confirm if you have the latest CC update installed on  your computer? If you do not, can you install the latest update and see if it helps?
    Preran
    Jan 28, 2014 1:00 AM   in reply to Tom Adobe
    @TOM Adobe -
    1. Can you please confirm if you are on the 13.2.0.6466 Build
    1. We have seen similar performance issues and are actively working on it . Can you please share the files with me at vharis(at)adobe(dot)com (Change the obvious to obvious!!) so that we can make sure that we fix this too
    Jan 28, 2014 11:07 AM   in reply to Tom Adobe
    Hi Tom,
    As a temporary work around, disable CSS to see if this improves performance.
    View > Style Rendering > Disable Styles.  This will allow you to work with un-styled pages in Design View.  But it won't effect either Live View or Preview in Browsers.
    Nancy O.
    Jan 28, 2014 12:17 PM   in reply to Tom Adobe
    Hi Tom,
    Am asking around. Let me see if I can get some answers for you in the time that the experts here try to solve it for you.
    Preran
    Jan 28, 2014 12:28 PM   in reply to Tom Adobe
    For what it's worth Tom, I work with big sites, too.  But I rarely use @import CSS.  I have yet to see any real benefit to them.  I much prefer direct links to external styles and have no performance problems with this workflow.
    Nancy O.
    Jan 28, 2014 10:28 PM   in reply to Tom Adobe
    @TOM Adobe - Thank you for reporting this to us . We have an internal issue logged and will investigate it .
    I will kep you updated on this
    Feb 19, 2014 5:28 AM   in reply to Tom Adobe
    I got the same problemz here I think.. I'm currently working on a campaign monitor email template.. (loads of evil tables included) and switching to design mode takes about 30 seconds to a minute
    Feb 20, 2014 9:24 PM   in reply to Tom Adobe
    @ Tom , It is very unfortunate that DW freezes on working with such files . We are looking at this issue on priority and I will update you once we have a fix for this issue
    Mar 12, 2014 12:19 PM   in reply to vharis
    Any updates on this? I'm having this same problem on a macpro 1,1 running 10.7.5. I've tried all the above fixes and then some with absolutely no success. Dreamweaver runs so slowly it's unusable. Activity monitor reports it as not responding constantly and trying to do a folder-wide find/replace took at least 20 minutes!
    Scott
    Mar 16, 2014 1:42 AM   in reply to vharis
    Please let me know when you have a solution to this issue as well.  I have had this issue with Dreamweaver ever since Mavericks and the Dreamweaver update.
    I do NOT use @import code (don't use bootstrap)
    With a recent update my pages seem to load faster... but all I have to do is click around on various images on my page within Dreamweaver... and I'm not "changing" anyhting... just randomly clicking images placed on a page... and within a couple clicks Dreamweaver has become so slow to "follow" my random clicks that it starts moving my images around -- in other words, it reaches a point where it's recognized the down-click but not the up-click of the mouse and is therefore 'moving' images rather than just selecting the different images.
    By the way -- the "Properties" update in Dreamweaver has ALWAYS been horrific.  If I'm updating links to a bunch of images I sometimes have to click an image three times to get the "Properties" tab to actually update.  This is not a new problem... been around for as long as I was forced to ditch GoLive.
    Back to the issue at hand... I have a page that has "SpryMenuBar.js" and "AC_RunActiveContent.js" and "SpryMenuHorizontal.css".  That's pretty much it (except for inline css).  My page contains a LOT of tables --- and a good number of tables nested in tables.  There are also about 27 iFrames on the page (all pulling in clocks or countdown timers).
    When I go from "Design" to "Split" or "Code" mode... there is only a 10-15 second wait.  If, however, I'm unfortunate to have to change even one character of code and switch back to "Design" view.... I'm lucky if I only have to wait 20 seconds for Dreamweaver to become responsive again.  The beach ball of death spins and spins and the "tool tip" for the cursor (which is a beach ball) flickers and flickers until Dreamweaver finally becomes responsive again -- almost as if Dreamweaver is re-reading the entire code and re-rendering the entire page extremely slowly each and every time I enter/exit code view.
    If I'm in "Code" view I can make any changes I want... and there are no problems, no lags, no slowdowns.  The beach ball of death only happens when I go back to "Design" view.
    If, however, I'm in "Split" view... then I will get the Beach Ball of death after every confirmed change I make to the code.
    When I'm only in "Design" view... I can pretty much leave my computer and go make a pot of coffee if I have the misfortune of having to copy and then paste a selected table, just as one example.  Even the most minor of updates seem to cause problems.  While in "Design" view only, I can click on an image... change the link for it... go to another image, change the link for it... but when I hit the third image... Beach Ball of Death.  This doesn't always happen on the third image... sometimes it's the 4th or the 2nd or whatever... I'm just saying that it's not 100% of the time with every action I take.
    I have duplicated the page, deleted the Javascript and CSS reference items and saved the page, quit Dreamweaver and relaunched to see if it was the Javascript or CSS causing the issues.  At first I thought there was huge speed improvements, so I thought it might have been one of those SprymenuBar widgets that was in a previous version of Dreamweaver causing the problem... but after a little bit of copy/paste work the slow-downs and Beach Ball of Death soon appeared once again.
    Ever since updating to Mavericks this performance issue has been obvious with Dreamweaver CC (latest build Version 13.2 Build 6466).  This problem is also obvious in Dreamweaver 6.
    My current solution is to use Dreamweaver 5.5.  It's a good thing I've been a loyal Adobe customer for as long as Adobe as been aquiring software -- and I still have all my old software.  I would ditch any hopes of ever using Dreamweaver CC again, and still be perfectly happy, if it weren't for a few bugs in Dreamweaver 5.5 (such as the pick-whip going in the opposite direction of the screen when I try to pick-whip something from my "Files" tab, like when assigning a link to a graphic).  Tiny oddities like that may make Dreamweaver 5.5 a bit of a pain to use for any real work... but for simply copy/paste and corrections on existing pages -- it operates at the speed I wish Dreamweaver CC could.  Well... aside from the fact that the "Properties" tab has NEVER been able to update in real-time in any version of Dreamweaver... everything else works at the expected and desired speed.
    So -- Dreamweaver 5.5 works.  Dreamweaver 6 and Dreamweaver CC make me want to take up an art class or watch daytime television to kill the time I have to wait in-between clicks and code corrections and copy/pastes... waiting for that Beach Ball of Death to stop spinning.
    By the way... when these "Beach Ball of Death" situations happen... the Activity Monitor shows Dreamweaver and WindowServer hitting some pretty high CPU loads for an extended period of time.
    Please keep us posted if you find a solution.  I've tried just about everything people have suggested on other threads and other boards... I've uninstalled Dreamweaver, reinstalled Dreamweaver... uninstalled Air and reinstalled Air... I've disabled all sorts of options like code assists and displaying external files and a bunch of other things... with no change at all in how Dreamweaver CC reacts.
    I would really like to see a solution to this issue quickly, as it's been many months now.  I've had no other problems with any of the other CC applications.
    Mar 16, 2014 4:20 AM   in reply to davidlgood
    Have seen exactly what you are talking about.
    In these forums there are many similar issues with different symptoms in different scenarios but it all boils down to the fact that since Maverick DWCC is now a tortoise .
    You can ask me to delete and reset new preferences, quit and restart, remove js files and all the other standard type responses but at the end of the day I now drink  a lot more coffee while waiting for DW to do stuff  in a long time that used to be done as a matter of course.. I thank god every day that illustrator has not gone the same way.
    Mar 18, 2014 2:59 AM   in reply to davidlgood
    Hi David,
    We are internally aware of a bunch of performance issues & slowness in DW on Mac 10.9.x
    We already had several connect sessions with users and observed the issue first-hand.
    Hopefully, all this will be addressed in the next subsequent update. Rest assured, we are working diligently towards fixing them.
    -Deep
    Mar 22, 2014 7:01 PM   in reply to subhadeep_banerjee
    Hi!
    I have the same problem since a couple of weeks on my Mac Pro 12 cores 32 gig ram !?! I have disable the "Display styles"... a little better but still slow compare to the first version DW CC. Some times i have to switch to work in Coda or  Edge Code.
    Very time consuming the actual DW !!!
    I'm waiting for this bug fix with my arm open...
    Mar 23, 2014 6:35 AM   in reply to Tom Adobe
    full windows pc mac computer even less problematic issues in
    http://bilimnettasarim.com
    Apr 8, 2014 5:46 PM   in reply to Novoweb
    How long must customers wait for an update? We are now forced to pay every month to use a product that never should have been released because it is unusable on a Mac. I've got a six-core Mac Pro running at 3.33 GHz with 48 GB of RAM and Dreamweaver is completely unusable. Scrolling is dreadful, typing even one word causes DW to churn. Trying to type a sentence takes tens of seconds.
    Hello, Adobe, you take our money and treat us like slaves.
    Apr 8, 2014 9:31 PM   in reply to rubydick
    @ rubydick,
    Drop me a mail at subbaner@adobe.com
    Apr 8, 2014 9:33 PM   in reply to rubydick
    I am with you on this one! Can't use it for about 2+ months now! Force to use Coda and it's slowing me down on my jobs!
    Hey Dreamweaver team? YouHou!
    Apr 10, 2014 6:37 AM   in reply to Novoweb
    Hi Novoweb,
    A number of Mavericks related bugs are being prioritized and in the pipeline to be fixed for the next update.
    Preran
    Apr 10, 2014 2:41 PM   in reply to Preran
    Hi Peran,
    Appreciate this but when is the next update????
    Apr 10, 2014 7:11 PM   in reply to Tropical Soul
    Yesterday I had a session with Adobe support (Subhadeep) where they verified that scrolling and typing stuttering make Dreamweaver unusable and it is not related to preference corruption. For users who must use DW (me, unfortunately), I discovered that the problem was somewhat diminished by resizing the DW window to make it smaller. But the problem is there in all screen sizes.
    At some point Adobe is going to have to recognize that many of their software packages have turned into bloatware. Rather than spending their time figuring out how to permanently tap into users' pocketbooks, they need to get back to producing good software at good prices. The record over the last decade is not promising. Adobe purchases Framemaker, then kills it on the Mac. Adobe purchases Macromedia, then kills Freehand, a product that hands' down trounces Illustrator. Illustrator's user interface is so bad that that it makes me want to go back to pen and paper. Then there is the constant shifting of menu and submenu commands. Just when you learn where something can be found, Adobe moves it.
    And the latest subscription-only debacle, which displays utter disdain for the needs of their customers. For more on the latter, see Thom Hogan's take: "The Fine Print in Adobe's Creative Cloud." When someone like that stands up to say it is wrong, Adobe would do well to listen.
    Apr 11, 2014 12:17 AM   in reply to Preran
    A idea of when the update will be here would be good. These issues have been around way to long.
    I'm trying to finish a simple 1 page list of size charts for a client and have only managed to edit 3 tables in 4hrs!
    My hourly rate is $88 so I think Adobe owes me at least the next 6 months of CC at no charge.
    S
    Apr 11, 2014 5:24 AM   in reply to Stephen Franklin
    Hi all,
    A number of bugs related to Mavericks have been prioritized for the next update. When the release date is announced by the company, we will post on this forum as well.
    Preran
    Apr 17, 2014 1:03 AM   in reply to Preran
    But until then, whenever then is, we have no compensation from Adobe for a bug they are aware. You still feel obliged to charge full price to all CC users??
    Apr 17, 2014 2:32 AM   in reply to Coupeman
    It's worse than that. In Nov. 2013 I discovered that Adobe had been double billing me for six months. Twice they promised me a refund, but in the end refused to give it. So they not only cheat their users by releasing shoddy software and charge full bore for it, but steal from users, as well.
    Apr 17, 2014 6:52 AM   in reply to rubydick
    Hi rubydick,
    Can you send me your Adobe ID over a private message so that I can look into what went wrong? It will help us improve our current processes.
    Preran
    Apr 17, 2014 6:59 PM   in reply to Preran
    Hi Preran,
    Yes, I can do that. How do I send you I private message?
    Apr 17, 2014 7:09 PM   in reply to Preran
    Not sure if this will work, but my ID is my email address:
    rubydick@ruby-sapphire.com
    If you look up the chat logs beginning in November 2013, you will see that Adobe constantly promised to get back to me and failed to do so, then after I kept after them, admitted twice I had been double billed for six months and promised to pay me back, then when I kept asking where the refund was, sent me a terse message saying that they had decided I was not double billed (even though I supplied transaction ID's).
    This all came about because of Adobe's ridiculous policy that one cannot change the country of an Adobe ID. Earth to Adobe: People do actually move from one country to another!!
    So I was forced to cancel one subscription and use another email address to start a new subscription. The only problem was, Adobe did not cancel the first subscription as they told me they would do. I didn't discover the error until six months later, in November 2013.
    In my experience, this is not a good way to treat paying customers. I've been using Adobe software since Photoshop version 1. I am not happy with the way Adobe has gone from being a great company to a terrible company.
    Sincerely,
    Richard Hughes
    Apr 18, 2014 6:21 AM   in reply to rubydick
    Hi rubydick,
    Thank you for the detailed information. I am checking with our teams to see how we could help you better and also improve our systems if required.
    Preran
Bookmarked By (1)
