I have an advanced action that evaluates certain criteria. The advance action is called from several different slides within the presentation. Is there some way that I can get it to display a set image if the criteria is met? It seems like I would have to write a new, slightly different advanced action on each slide to "show" the image on each slide.
Is there some way to share an image (or button) so that the advanced action can make it appear, no matter what slide you are on?
Let me know if I need to provide further clarification. Thanks!
Technically your advanced actions are only allowed to show or hide images from the slide where they are actually executed. So an advanced action executed on slide 3 for example, will not be able to show or hide an image on slide 5.
However, what you can do is place the image on one of the earlier slides in the project and then set it to be timed for Rest of Project. This allows you to SHOW or HIDE the image from any slide later in the project where your Advanced Action is executed.
Perfect - that does it!
