thesantifox
Premiere Adding Frames in Render
Jan 28, 2014 5:00 PM
Tags: #video #premiere #editing #render #sequences
So here's the backtracking of what I did:
Edited my footage in a sequence in normal size.
I wanted to make it widescreen, so I made a new sequence in 1920x810.
I then copy pasted my edit into the new sequence and started rendering.
The render window kept adding frames to render, and the percentage jumps and very slowly adds 0.1% into the progress.
I tried choosing a smaller amount to render, same problem still persists.
Why does it now want to render normally? Why does it add frames to render all the time? Wheres the problem?
    Jan 28, 2014 10:56 PM   in reply to thesantifox
    You're dimensions are weird.  Try 1920 x 800 instead, which is the standard 2.40:1 aspect.
    Jan 30, 2014 7:14 PM   in reply to thesantifox
    I was told that 1920x810 is the standard RED Wide format.
    I don't believe that's true.  At least, I've never seen those dimensions listed in any RED camera specs.
    More to the point, most deliverables are MPEG in one form or another, and MPEG works best when the dimensions are evenly divisible by 8.  So do give that 1920 x 800 a go and see what happens.
