Hello everyone, I'm developing apps for iOS with Adobe AIR since years but...I always had this big problem: how to make the app understand if I'm tapping something or if I'm just scrolling it?
In my last product I basically have a scrolling menu with some options to activate. So I need a way to determinate if I'm tapping a MovieClip or just scrolling it. Can you help me?
Thank you so much guys, have a nice day!
I use mouse down and mouse up events with a timer....when mousedown fires....timer starts....a tap would occur if the timer records less then 0.1 seconds....scroll would be longer....timer ends when the mouse up event fires....
?...instead of timer, you could also use a measure of distance from where the original touch took place to when the touch no longer is recorded.....less then a certain distance would represent a tap.....I have used a combo of both tecniques.....I stay away from touch events as they are more intensive on cpu.
I would not agree on using Timer event, instead I would use (and I've been using) this:
sprite.addEventListener(MouseEvent.MOUSE_DOWN, mouseDownHandler);
var moving:Boolean;
function mouseDownHandler(e:MouseEvent):void
sprite.addEventListener(MouseEvent.MOUSE_MOVE, mouseMoveHandler);
sprite.stage.addEventListener(MouseEvent.MOUSE_UP, mouseUpHandler);
//record mouseX and mouseY in variable
function mouseMoveHandler(e:MouseEvent):void
moving = true;
//set sprite's coordinates
function mouseUpHandler(e:MouseEvent):void
if (moving)
//it means it is scrolling
} else
//it means it is a click only..
