d16moore
Edit ClipboardFormatsPriorities in maker.ini file
Jan 31, 2014 9:38 AM
Tags: #text #framemaker10 #framemaker #10 #paste_special #maker.ini #clipboardformatspriorities
FrameMaker 10 (v. 10.0.2.419), Window 7.
When copying text from Word into FrameMaker, I would like "TEXT" to be the first item in the dialog box when using Paste Special.
We have edited the ClipboardFormatsPriorities in the maker.ini file by moving TEXT from the end to the beginning of the line:
ClipboardFormatsPriorities=TEXT, FILE, MIFW, MIF, RTF, OLE 2, META, EMF,  DIB, BMP, UNICODE TEXT
So far, the changes have not taken affect.
Can this be done?
Debbie
    Jan 31, 2014 9:50 AM   in reply to d16moore
    There are two maker.ini files; one system, one (for each) user.
    Which did you edit?
    I assume the user file has the last word, but don't really know, as this isn't an issue on the old FM I run.
    And did you exit and re-start FM?
    That should do it – which maker.ini did you change? Check both of them to make sure that the user one is overriding the “factory” one.
    Jan 31, 2014 10:38 AM   in reply to d16moore
    Debbie,
    This maker.ini entry sets the priority for the standard paste (ctrl + v), not the Paste Special (ctrl + shift + v).
    Jan 31, 2014 10:57 AM   in reply to d16moore
    Sorry – I completely missed the “Paste Special” part of your OP – the whole point of messing with this line is so you don’t have to bother with the “special” part of it, LOL ;>)
    Jan 31, 2014 12:44 PM   in reply to d16moore
    Yes, it saved me buckets of time when copying/[pasting from Word source docs
