Find and Replace not finding string
Jan 31, 2014 4:20 PM
Using robohelp html v10 on win 7
I want to clean up some html in a project imported from framemaker.
In this example i want to find all instances of <li><p> and replace all with <li>
here is an example:
<ol style="list-style: decimal;">
<li><p>Merge any data files and select the merged file.</p></li>
<li><p>From the Channel/SSID List, click the Channel tab and highlight
  the channels adjacent to each other, such as Channels 1, 2, 3, or
  4, 5, 6, etc.</p></li>
<li><p>From the Data Type drop-down menu, click Ch. Interference.</p></li>
<li><p>On the Legend bar, set the minimum interference level to be
  shown. This ensures that only areas that exceed a certain amount of
  interference are displayed.</p></li>
</ol>
A global find/replace on the project level is not finding the string, however, if I first select the text shown above in design view and click "clear formatting" and then do the global find/replace, it finds only that text and makes the change.
I have this same issue trying to do a global replace from <td><p> to <td> in tables
Kind of frustrating not to be able to make this change globally.
Any idea what is happening? Any solution?
    Feb 6, 2014 7:39 AM   in reply to jeffc2010
    How are you doing the global search?
    Find and Replace in Files should search for <li><p> and replace with <li> then search for </p></li> and replace with </li>
    Do back up first as that sort of operation can wreck a project in seconds if you didn't get something quite right.
    @petergrainge
    Feb 6, 2014 11:02 AM   in reply to jeffc2010
    I just set up a simple test and it worked as it should so I don't know what is preventing that for you.
    Import a couple of topics that are causing this problem into a new project. Do they still cause problems?
    When you do a search where the string is not found, do you get a dialog to confirm that?
    @petergrainge
