Tutorial: Accessing function from external swf with SWFLoader
Feb 15, 2014 3:35 PM
Tags: #swfloader #localconnection #flex4.6
Hello Ladies & Sirs,
i am working with Spark ( Flex SDK 4.11, SWFLoader and LocalConnection ).
Method 1: SWFLoader and LocalConnection:
The local connection only works the function because the function is the string. The application loads the file of the address. The external file has published its own function, which you can access from the SWFLoader or engage in parallel.
This is Main.swf:
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                                 creationComplete="initApp(event)">
          <fx:Script>
                    <![CDATA[
                              import mx.events.DragEvent;
                              import mx.events.FlexEvent;
                              protected var con:LocalConnection;
                              protected function initApp(event:FlexEvent):void
                                        btnCall.addEventListener(MouseEvent.CLICK, btnClick);
                                        con = new LocalConnection();
                                        con.addEventListener(StatusEvent.STATUS, onConnect);
                                        swfLoader.addEventListener(DragEvent.DRAG_COMPLETE, onCompleted);
                              private function btnClick(event:MouseEvent):void
                                        con.send("appdomain", "openPanel");
                              protected function ClosePanel(event:MouseEvent):void
                                        con.send("appdomain", "closePanel");
                              private function onCompleted(event:Event):void
                                        swfLoader.autoLoad = true;
                              private function onConnect(event:StatusEvent):void
                                        switch (event.level){
                                                  case "status":
                                                            labelStatus.text = "Panel loaded from external swf ;-) and it works fine :)";
                                                            break;
                                                  case "error":
                                                            labelStatus.text = "Error: It can't call..."
                                                            break;
          </fx:Script>
          <fx:Declarations>
                    <!-- Platzieren Sie nichtvisuelle Elemente (z. B. Dienste, Wertobjekte) hier -->
          </fx:Declarations>
          <s:Button left="10" bottom="10" label="Open Panel" id="btnCall"/>
          <s:Label id="labelStatus" left="205" right="10" bottom="10" height="21" paddingLeft="2"
                               paddingRight="2" paddingTop="2" textAlign="left" verticalAlign="middle"/>
          <s:SWFLoader id="swfLoader" left="10" right="10" top="10" bottom="39" scaleContent="true"
                                         source="MyPage.swf"/>
          <s:Button left="108" bottom="10" label="Close Panel" click="ClosePanel(event)"/>
</s:Application>
And this is MyPage.swf:
          <fx:Script>
                    <![CDATA[
                              import spark.components.Alert;
                                        con.client = this;
                                        try{
                                                  con.connect("appdomain");
                                        }catch(error:ArgumentError){
                                                  Alert.show("Error: It can not connect your correct domain.");
                              public function openPanel():void
                                        this.panel.visible = true;
                              public function closePanel():void
                                        this.panel.visible = false;
          </fx:Script>
          <fx:Declarations>
          </fx:Declarations>
          <s:Panel id="panel" visible="false" width="250" height="200" horizontalCenter="0"
                               title="Open from external SWF!" verticalCenter="0">
          </s:Panel>
</s:Application>
If you run application than it works fine.
And there are examples of pictures:
http://my.funpic.de/show-photo/803489-PIC.png
http://my.funpic.de/show-photo/803490-PIC.png
Yeah it works good.
Method 2: SWFLoader and SystemManager:
The system manager can access through external files via variables and functions. System Manager can perform everything when you click the main file or side file, the SWF files can affect all functional.
I am working with FlexLib 2.5 ( MDICanvas and MDIWindow) Now i have used Main.swf which loads MyPage.swf. This works fine.
This is Main.swf:
               xmlns:flexlib="http://code.google.com/p/flexlib/"
               creationComplete="creationCompleteHandler(event)">
    <fx:Script>
        <![CDATA[
            import mx.managers.PopUpManager;
            import mx.managers.SystemManager;
            [Bindable]
            private var extSM:SystemManager;
            private var _externalSwfLoaded:Boolean;
            [Bindable]
            public function get externalSwfLoaded():Boolean
                return _externalSwfLoaded;
            public function set externalSwfLoaded(value:Boolean):void
                _externalSwfLoaded = value;
            protected function creationCompleteHandler(event:FlexEvent):void
                var context:LoaderContext = new LoaderContext();
                context.applicationDomain = ApplicationDomain.currentDomain;
                loader.loaderContext = context;
                loader.load("MyPage.swf");
            protected function loaderCompleteHandler(event:Event):void
                extSM = loader.content as SystemManager;
                //    Set the swf loaded flag if you have the SystemManager
                if (extSM)
                    externalSwfLoaded = true;
            protected function loaderIoErrorHandler(event:IOErrorEvent):void
                trace(event.toString());
                Alert.show(event.type + ":" + event.text, "IO error occured");
            protected function openPropreties(event:MouseEvent):void
                Object(extSM.application).openPropretiesWin();
                canvas.windowManager.add(Object(extSM.application).openPropretiesWindow);
    </fx:Script>
    <fx:Declarations>
    </fx:Declarations>
    <s:SWFLoader id="loader" left="0" top="0" bottom="40" width="100%"
                 complete="loaderCompleteHandler(event)" ioError="loaderIoErrorHandler(event)"
                 trustContent="true"/>
    <s:Button left="150" bottom="10" label="Open Propreties" click="openPropreties(event)"/>
    <flexlib:MDICanvas id="canvas" left="0" right="0" top="0" bottom="39">
    </flexlib:MDICanvas>
</s:Application>
               backgroundAlpha="0" creationComplete="initApp(event)">
    <fx:Script>
        <![CDATA[
            import flexlib.mdi.containers.MDIWindow;
            [Bindable]
            public var openPropretiesWindow:MDIWindow;
            public function openPropretiesWin():void
                openPropretiesWindow = new MDIWindow;
                openPropretiesWindow.width = 300;
                openPropretiesWindow.height = 400;
                openPropretiesWindow.title = "Propreties";
    </fx:Script>
    <fx:Declarations>
    </fx:Declarations>
</s:Application>
If I run the application, it works fine.
There are examples of pictures:
http://i.stack.imgur.com/f43Ge.png
http://i.stack.imgur.com/T8sVF.png
http://i.stack.imgur.com/CFkjT.png
They are original swf files:
http://i.stack.imgur.com/HBQVK.png
Thank you for support and help I have improved post because i have bad english. I am sorry for that. Thank you!
I would like to apologize for you
// EDIT: I am sorry for that because spark components won't work from loading swf application when you open MDIWindow with same components like TextInput or TextArea and any components and they can not work after openning MDI-WIndow when Flash player was debugged since events stop again
It is very bad
I found better solution: We use only mx-component ( Flex SDK 3.6.0a or 3.7. They component ( <mx...> very better than spark components...
This is MainDesktop.swf
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                                        creationComplete="creationCompleteHandler(event)" layout="absolute">
          <mx:Script>
                    <![CDATA[
                              import mx.controls.Alert;
                              [Bindable]
                              [Bindable]
                                        loader.load("PropretiesApp.swf");
                                        extSM = loader.content as SystemManager;;
                                        if (extSM)
                                        Object(extSM.application).openPropretiesWinCall();
                                        canvas.windowManager.add(Object(extSM.application).propretiesWindow);
          </mx:Script>
          <flexlib:MDICanvas left="0" right="0" top="0" bottom="40" id="canvas">
                    <mx:SWFLoader left="0" right="0" top="0" bottom="40"
                                                    id="loader" trustContent="true"
                                                    ioError="loaderIoErrorHandler(event)"/>
          <mx:Button left="10" bottom="10" label="Open Propreties" click="openPropreties(event)"/>
</mx:Application>
This is PropretiesApp.swf:
                                        layout="absolute"
                                        backgroundAlpha="0">
          <mx:Script>
                    <![CDATA[
                              import mx.controls.TextArea;
                              import net.sourceskyboxer.PropretiesWindow;
                              [Bindable]
                              public var propretiesWindow:PropretiesWindow;
                              public function openPropretiesWinCall():void
                                        propretiesWindow = new PropretiesWindow();
                                        propretiesWindow.width = 600;
                                        propretiesWindow.height = 400;
          </mx:Script>
</mx:Application>
and this is component "PropretiesWindow":
<ns:MDIWindow xmlns:mx="http://www.adobe.com/2006/mxml"
                                xmlns:ns="http://code.google.com/p/flexlib/"
                                horizontalScrollPolicy="off" layout="absolute" title="Propreties"
                                verticalScrollPolicy="off">
          <mx:RichTextEditor left="-9" right="-9" top="-28" bottom="-9" title="Titel">
          </mx:RichTextEditor>
</ns:MDIWindow>
I am sorry for worng name like "Propreties WIndow"  or "Editor Window".
I create component from propretiesWindow because i am testing for different version for spark and mx. Because mx components are very better than spark components.
Look at picture
http://my.funpic.de/show-photo/805652-PIC.png
This works awesome!!!!!!!! Why does spark framework not work for loading swf application. That is crazy because spark components have not single components because they are using rsl format
MX-Components have not problems for compressed single code. This works only MDIWindow with one or more components... I am very happy because we have used old version
Best use only mx components  regards and greeting from Germany,
Jens Eckervogt.
