knock out harsh tones?
Feb 2, 2014 3:37 PM
Pretty often I want to suppress cymbol sounds and other raspy harsh stuff.
Is 30 band equalizer the best choice?  Usually around 4k, 5k, 6k.  Is there some
tricky better way?
    Feb 2, 2014 11:40 PM   in reply to Steve Zeeeee
    It depends a bit on the effect you need.  The 30 band graphic is good if you want a gentle cut over a range of frequencies.  However, if you can identify one or two seriously bad single frequencies, then I might try the parametric EQ, find the ideal centre frequency, adjust the width (Q)  to the least you need and cut as required.
    The 30 band graphic is like a butterknife--great for broad brush strokes stuff.  The parametril is more like a surgical scalpel.
    Feb 8, 2014 2:14 PM   in reply to Steve Zeeeee
    Actually I have found the Multi-Band Compressor preset "Kill the Harshness" to be very effective at taking care of cymbol sounds and other raspy harsh stuff.
