lisadames
Wrong PDF file generated from FM 10 book
Feb 3, 2014 8:37 AM
Tags: #framemaker10 #save_as_pdf
Sometimes when I generate a PDF from a FrameMaker 10 unstructured book, the generated PDF overwrites an existing file with a totally different name and location.  After I try a few times without changing anything, it finally does it right.  Any ideas?
    Feb 3, 2014 8:42 AM   in reply to lisadames
    Are you printing to the AdobePDF printer instance or Saving As PDF?
    Feb 3, 2014 11:12 AM   in reply to lisadames
    Lisa,
    You can always set Distiller Preferences to prompt you bfore over-writing an existing file. This way you can intercede if it's doing somehting it's not supposed to.
    IF Distiller has the correct filename in its internal log, how do you know that it is the culprit overwriting an exising file with a totally different name and location?
    Feb 3, 2014 2:10 PM   in reply to lisadames
    If you really want to get to the bottom of what's grabbing and overwriting(?) your files, you could use Microsoft's Sysinternals Process Monitor (Procmon) available from here:
    http://technet.microsoft.com/en-us/sysinternals/bb896645
    You can configure the filters to watch what's going on in a folder or on a file, but it's a bit geeky to setup all the filters - it also logs a ton of data, so interpreting it or tracking down an event could also be tedious. If you have an IT department, they  should be consulted and could help set this up.
    Here is an article that details how to set up the Process Monitor to watch specific files:
    http://www.veryant.com/support/phpkb/question.php?ID=136
    Otherwise, just run Distiller with the Ask setting, to see if something odd is happening at this stage. If you're still getting mysterious deletions, then dig deeper with the Process Monitor.
