KellyClem
frozen files
Feb 4, 2014 8:07 AM
I made updates to a user manual and now I am unable to open one of the folder links.  It is one of the folders in which I made updates.  When I try to open the folder, the file freezes and all the other files freeze up to.  Other files can be opened, but only if I do not open the problem file first.  I am very new to RoboHelp, did I generate and publish incorrectly?  I am trying to find a way to fix this problem.  Thank you.
    Feb 6, 2014 7:43 AM   in reply to KellyClem
    The problem only occurs on the one file, correct? A few
    questions/suggestions:
    • You make a remark about publishing. Does the problem occur in the
        published help, in the project or both?
    • Could it be that your published output have ended up in your project
        source? If you see lots of red squares in your topics, this has
        probably happened.
    • What happens if you open the culprit topic with Notepad, remove the
        content and save it? Can you open the topic than. (Just remember to
        save the contens under a different name first.)
    Kind regards,
    Willam
