Brendan.JB
Unusual render times
Feb 4, 2014 5:41 PM
Tags: #file #slow #render #small #long #too #fluctuate
Hello, I seem to be experiencing weird, fluctuating render times with my projects. Some 10+ minute projects render in 20 minutes or so, others like the one below take far too long for what they are.
I am running a Macbook Pro, 2.5ghz Intel Core i7, 8GB 1333 Mhz DDR3 ram, and an AMD Radeon HD 6770M 1GB.
Here is a current project I am working on at the moment - please excuse the blurred sections, this is an internal business video and I am required to do this for security.
The maximum filesize will only be est. 134mb, the length of the video is 3 and a half minutes, and I am only rendering at 720p with 90 second keyframes. When I render this file it takes upwards of 2 hours; sometimes longer.
The source files are 1920x1080 and 1440x1080, and I have 4-5 nested sequences approx 10-20 seconds long each with warp stabilizer applied to them.
I also have fast color corrector applied to all clips. I usually have a VBR of min-4 max-6 but attempted to change it to CBR to see if that decreased rendering time; it didn't.
I've also tried optimizing the memory for both rendering and memory in the preferences window, but I see no difference.
Can you spot anything that might be causing this render to take so long?
Thanks in advance for your help.
Brendan
    Feb 4, 2014 5:52 PM   in reply to Brendan.JB
    I am not surprised!
    You got a ot going on there in the differences between source and export
    Frame rate : PAL to NTSC...
    Square pixel to rectangular
    Dimension change
    WHy did you choose those settings?
    Did source footage match the project settings?
    Feb 4, 2014 6:37 PM   in reply to Brendan.JB
    Sounds like random settings choice issue!
    So...
    what are the source files?
    what was the sequence setting?
    Feb 4, 2014 7:01 PM   in reply to Brendan.JB
    Hmmm
    You still got a lot going on there with mixed media, fx, warp stab. etc...but I cant see anyway around it in your case.
    Sorry.
