kaka2kool
Multi-point publishing with MBR - Help!
Feb 6, 2014 3:03 AM
I've been trying MPP for the last few days and it works fine for single stream but when I have 3 stream, at different bitrates, pnly the last one works, other work for short period and then they stop
Here is the code I am using. Please guide as to how I can change this code to republish more than one stream!
// Called when the client publishes
application.onPublish = function(client, myStream) {
    trace(myStream.name + " is publishing into application " + application.name);
    // This is an example of using the multi-point publish feature to republish
    // streams to another application instance on the local server.
    if (application.name == "live/_definst_"){
        trace("Republishing the stream " + myStream.name + "into /livepkgr2");
        nc = new NetConnection();
        nc.connect( "rtmp://localhost/livepkgr2" );
        ns = new NetStream(nc);
        // called when the server NetStream object has a status
        ns.onStatus = function(info) {
            trace("Stream Status: " + info.code)
            if (info.code == "NetStream.Publish.Start") {
                trace("The stream is now publishing");
        ns.setBufferTime(2);
        ns.attach(myStream);
        ns.publish( myStream.name +"?adbe-live-event=liveevent", "live" );
application.onUnpublish = function( client, myStream ) {
    trace(myStream.name + " is unpublishing"  );
