Audio is off sync towards end of exported film
Feb 11, 2014 3:52 PM
Tags: #off #flash #audio #exporting #to #sync #is #.mov #rendering_timeline
I am having an issue which makes no sense so here goes... I animated a short piece which some lipsync in it. I exported it via the Media Encoder. It works perfectly at the beginning but the last two lines of dialog are off a number of frames which makes no sense. The preview in Flash works fine but when I render it the lines are off whether it's swf, flv, mp4 or any format Flash can spit out. Both CS 6 NAD Flash CC do this yet like I said if you play it in the timeline it's dead on sync.
The frame rate is the same in the file and the exporter so that's not it. I can't figure out why. Any thoughts? It was animated in Flash CS6 and then rendered in Flash CC because Flash CS6's rendering is a bucket of poo at best. Any help would be greatly appreciated.
    Feb 12, 2014 6:19 AM   in reply to Asymetrical
    While I don't know where the problem may be, you might be able to work around the problem by segmenting your Flash file and then exporting to video in segments. You can then put the pieces back together in a video editor.
