derbaderp
how the f*** do i download encore in this stupid f***ing adobe world
Feb 11, 2014 7:44 PM
I gues chat help is closed now.  And I'm stuck navigating the convoluted s**tbox that is the creative cloud.
    Feb 11, 2014 8:04 PM   in reply to derbaderp
    Talk pretty to the page...
    I do believe that it works as long as you follow the links. But it sure is an annoying process.
    Sorry; I don't have cloud and can't walk you through the steps. Also, what you see varies depending on whether you are logged into your subscription and what you already have installed.
    In case you haven't seen the following (I hope you have, but...):
    See this link, which includes how to install Encore CS6, how to get the library, and a tutorial on workflow with Premiere CC.
    http://helpx.adobe.com/encore/kb/encore-cs6-installed-cc.html
    Also, see the Encore CC/CS6 FAQ:
    http://www.adobe.com/products/encore/faq.html
    Edit: if that doesn't work, post a screenshot of the page where you are stuck.
    Feb 11, 2014 8:42 PM   in reply to derbaderp
    Okay, Premiere CS6 just downloaded.  I'll complain some more later.
    That's good news!
    Thanks for reporting back. Nothing like a little venting to make things better in your own fiefdom, whatever spelling is correct!
    Be sure to read ALL OF THE LINKS inside the first, instruction link that Stan posted
    There are several downloads to get everything, and installing from the downloads is more than a bit convoluted
    Things were SO much simpler with CS5 where everything was included on a delivery DVD and the install process was all from a setup program
    Feb 12, 2014 10:26 AM   in reply to derbaderp
    Call it Cloud, or simply a web site download... the IMPLEMENTATION is the key... I have purchased other programs using download instead of disc, and the process is pleasant when the download contains EVERYTHING NEEDED to do the install in one file... just as CS5 was on one disc (well, several if you were buying a suite)
    I have no understanding at all of why Adobe CHOOSES to make installing PPro/Encore CS6 to difficult... CS6 has been out long enough that I would THINK it would be simple for someone there to put everything together into a one file package, with comprehensive setup installer
    Anyway, glad you are forging ahead... in spite of Adobe's fragmented process
