Dave Lalande
Really bad audio cleanup
Feb 12, 2014 12:02 PM
Tags: #audio #audition #noise #voice #cc #noise_reduction
I'm a novice at Audition.  I've spent the better part of the day trying to clean up this audio with no real luck.  Will an expert help me with this and if you can tell me the trick?
I'm getting the feeling that this audio is just too bad to be cleaned up for use in a video.
Dave
    Feb 12, 2014 12:18 PM   in reply to Dave Lalande
    I don't know that you'll ever get it perfect, but you can get better results that may be usable depending on what you're working on.
    I first amplified the file +12dB using the on-screen volume control.  I then zoomed into the first 4 seconds of the file and selected the region from 0:00.00 to 0:00.8, which was just the camera buzz and hiss without any speech.  I opened the Noise Reduction effect then exposed the Advanced section at the bottom.  I changed the FFT Size to 512 (after a few tests with higher values, this sounded best) and clicked the Capture Noise Reduction button at the top.
    I then removed the selection, by clicking in the waveform and adjusted these values:
    Noise Reduction: 80%
    Reduce By: 22dB
    Spectral Decay Rate: 75%
    Certainly not perfect, but the buzz is gone and the hiss is greatly reduced.  The speech is audible and the reverberation artifacts are reduced.  You can certainly play with these settings to find a happy medium between noise and warbly artifacts, though.
    Good luck!
