Rosyln Dakota
Version Control settings
Feb 12, 2014 4:56 PM
Tags: #dreamweaver_cs5
I'm a student using Dreamweaver CS5. I'm trying to upload files to a remote site. In the Remote Server pane I can't see the files under Remote Server. Just a message "To see the files in your repository, you must define its Version Control settings." How do you do that?  I've typed it into all the help fields and can't get an answer. Thanks.
    Feb 12, 2014 8:39 PM   in reply to Rosyln Dakota
    It could be that you haven't defined the site correctly.  First I suggest go to:
    Site >> Manage Site
    At the next window, select the site you have defined from the list.  If the list is blank then you need to define the site by clicking on the New button
    However, if the list is bot blank then just the site that is giving you the problem and then go to Version Control
    at the version Control dial;og box make sure the Access box is "None" and everything else is greyed out.
    Now save it and this should solve the the problem you are having.
    Good luck.
